Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority - View Single Post - 1300hp 2JZ GTE swapped Mitsubishi Eclipse for 5 million
Old November 29th, 2019, 07:34 AM   #1 (permalink)
n-e-o
AWD swapper
n-e-o's Avatar
Vehicle: 06/G4/GT AWD 09/G4/spyder
n-e-o will become famous soon enough
There isn't a single build in the world like this one. This car is based on a 2nd gen Mitsubishi Eclipse platform, and was built by Full-Power-Motors racing team for the sole purpose of breaking records in the FWD category of Russia's national drag racing championship. What makes this car unique is its transverse mounted 2JZ-GTE motor. Mind you, the engine is driving the front wheels. And after a two year hiatus, Full Power Motors' Mitsubishi Eclipse, which was the fastest front-wheel drive car back in 2015, is back.
Today I'm visiting Sergei Starshinov, the owner of this 1300-horsepower beast. He'll be filling is in on the technical side of his build, and telling us how much it costs to build a championship winning car. This one actually holds a special place in my heart, since it used to be mine.
Short list of tuning part used in this project:
- factory engine block 2jz-gte modified to strengthen
- the cooling jacket is completely filled with cement
- Crankshaft-OEM.
- Pistons CP-Pistons compression ratio 10:1
- R&R connecting rods (aluminum)
- Steel towbars (fpmotors)
- ACL bearings (with increased clearance)
- dry sump (FPmotors)
- clutch TILTON 3 disc carbon
- flywheel: steel (FPmotors)
- GARRETT 4718gtx turbocharger
- exhaust sys custom (FPmotors)
- intake sys custom (fpmotors)
- Bosh 2200cc 12pcs fuel injectors
- the ignition coils AEM
- engine control unit ABIT
- oil pump 3x section Barnes
- with Magnafuel 1000 fuel pump
- 4-speed transmission (base mitsubishi evolution 9)
- straight-toothed range (FPMOTORS)
- gear case (fpmotors)
- sequential control system
- drive shafts (FPmotors)
- front hubs (fpmotors)
- suspension arms (fpmotors)
- shock absorbers STRANGE
- Simpson 12" parachute braking system
- Brakes front: Strange Drag
- Rear brakes: Wilwood
- body D31a mitsubishi eclipse 2G
- aerodynamic body kit (fpmotors) carbon fiber
- seat SPARCO carbon
- Sparco steering wheel
- Wheels before: Weld Racing 15x12
- Wheels rear: Weld Racing 174
- Tire front: M&H 2910.5
- Tire rear: Hoosier 274
#ZergBush #mitsubishi #mitsubishieclipse
n-e-o is offline   Reply With Quote
