Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority - View Single Post - WTB: GT V6 Emgine Wiring Harness
Old January 11th, 2020, 08:02 AM   #10 (permalink)
Sabertooth^2
Yeah, it's actually not a whole lot on an engine harness.
Quick list:
Injectors, crank position sensor, cam position sensor, coilpack plugs, MIVEC solenoid, coolant temperature sensor, oil level sender, MAF sensor, MAP sensor, throttle body, EGR (you can use a vacuum EGR from an evo 8, no plugs, or delete it), alternator, power steering, ABS... And with creativity you can remove some of that stuff or use alternate systems
