Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority - View Single Post - How to turn a rusty exhaust manifold into a trick header . L52 engine header fabricat
Old May 27th, 2020, 05:15 PM   #1 (permalink)
n-e-o
AWD swapper
n-e-o's Avatar
Vehicle: 06/G4/GT AWD 09/G4/spyder
n-e-o will become famous soon enough
In order to rebuild an old, rusty motor, you need to go through every single component. As a matter of fact, you'd be better off replacing factory parts with aftermarket goodies. On a Hummer H3, replacing the stock cast iron exhaust manifold is a necessity, due to it being prone to cracking. I've made a high-flow replacement manifold with equal length runners using AISI 304 stainless steel. Each runner is 42.4 mm wide, wall thickness is 3 mm, while the 5-1 merge collector is 60 cm long. These specs allow for increasing engine efficiency and improving exhaust gas flow out of the cylinders on this inline-5 L52 Vortec 3500 GM's engine. This exhaust manifold is durable enough to allow for installing a turbocharger. The manifold was made using a TIG-welder fed with argon. This timelapse video shows the entire process of how the exhaust header was made.
n-e-o is offline   Reply With Quote
