Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority - View Single Post - Oil Leaking
Thread: Oil Leaking
Old September 14th, 2020, 12:03 PM   #1 (permalink)
alovid19
Vehicle: 09 GS Manual
alovid19 is on a distinguished road
Oil Leaking
Hi y'all I noticed some oil leaking under my car. It not too bad but i think its transmission oil because its right next to the CV Drive Shaft axle. I noticed that there is a little clean cutout hole in the same spot underneath so its a factory cut, right? I also put in Redline trans gear fluid in recently so i think that I put just a bit too much and the oil leaks through that factory hole. Or would it be leaking because of some mechanical issue? Can y'all give me your opinion before i take it to the mechanic?
Thank you in advance for any response you may offer!
alovid19 is offline   Reply With Quote
