Coolant/dying issue - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > General > 2000-2005 Eclipse (General 3G)
2000-2005 Eclipse (General 3G) General discussion and information about 2000~2005 (3rd Generation) Eclipse
Old June 12th, 2018, 05:15 PM   #1 (permalink)
Bigmason01's Avatar
Bigmason01 is on a distinguished road
Coolant/dying issue
So I was driving my 3g and It died when I stopped at a stop sign and Then again at another stop, so I was putting it in neutral and keeping the rpms high enough to keep it alive, then started getting steam dumping from hood so pulled over and I looks like the radiator cap busted halfway off and sprayed coolant on the engine. I let it cool and tried making it home but I couldent get it going because as soon as I turned the key and tried keeping it alive the car was shaking and sounded really bad and was having a hard time staying alive at 1500 rpms so I parked the car and left it there and hoping some one can give me insight. 2000 eclipse gt auto trans
Bigmason01 is offline   Reply With Quote Quick reply to this message
Old June 12th, 2018, 05:43 PM   #2 (permalink)
Should look into why it overheated so much that the rad cap blew off. A failed head gasket could cause that, and would also cause rough idling/no idling at all possible due to coolant seeping into 1 or more cylinders. You'll also have a lot of gasses coming out of the radiator from the exhaust mixing into the coolant. Any white vapor out the tail pipe?
Old June 12th, 2018, 07:12 PM   #3 (permalink)
Bigmason01's Avatar
Didn’t see any but I’ll check that when I go back to the car. Man a head gasket would really suck
Old June 12th, 2018, 08:40 PM   #4 (permalink)
Joshinator99's Avatar
Vehicle: 2006 Eclipse GS
Joshinator99 is on a distinguished road
Originally Posted by Bigmason01 View Post
Didnít see any but Iíll check that when I go back to the car. Man a head gasket would really suck
Along that line... take a look at your oil on the dipstick...see if there is any sign of coolant in it. You can also look at the coolant bottle to see if there is any sign of oil in it.
Joshinator99 is offline   Reply With Quote Quick reply to this message
Old June 12th, 2018, 10:38 PM   #5 (permalink)
Bigmason01's Avatar
I filled radiator with water and started it no smoke out tail pipe and I did think to check dipstick no signs of coolant and drove home it got a little hot but that’s it. Car has brand new radiator (how it was when I bought it a few weeks ago) so I’m thinking they blew head gasket got oil in the cooling system had to get new radiator and got rid of car ASAP and I’m the victim kinda feel dumb for not catching it and now that I think of it when cleaning engine bay I saw residue in bottom of coolant tank so im pretty sure head gasket is blown but tomorrow I will drain cooling system and maybe oil too and see what I can come up with.
Old June 13th, 2018, 04:40 AM   #6 (permalink)
Washed spark plugs is another sign. Can check those. Ones burning coolant would be cleaner looking.
Could be a bad water pump or bad thermostat. Does your coolant flow through the radiator?
Old June 13th, 2018, 01:08 PM   #7 (permalink)
Bigmason01's Avatar
Was also thinking could be thermostat. What’s easiest way to make sure coolant is running through? I’m not really sure it is I think the radiator is clogged and pressure built up and that’s why rad cap popped because temp wasn’t reading hot when that happened
Old June 13th, 2018, 01:40 PM   #8 (permalink)
Bigmason01's Avatar
This is out of radiator that had some green coolant and the rest water
File Type: jpg 85DDD6EA-A2D3-41F2-9B5B-9ED9EE2CB8D1_1528915231950.jpg (23.3 KB, 9 views)
Old June 14th, 2018, 11:55 AM   #9 (permalink)
Bigmason01's Avatar
So oil is getting in radiator but no coolant/water in oil. Head gasket would cause both to mix correct? Would oil pressure be higher than coolant so coolant could never get to oil? Hopefully this doesent mean the head is warped?
File Type: jpg 3FC692A1-25CD-483D-B8C1-BDD140522ED0_1528995356675.jpg (19.4 KB, 6 views)
Question: Confusing issue - No power steering / car dying trippysheep94 2000-2005 Eclipse (General 3G) 2 November 4th, 2017 07:32 PM
Minor Steering Play Issue Porcupinepuffer Problem Reports 1 November 30th, 2016 11:07 AM
Header issue Charlesdcann 4G Eclipse GS/SE Specific 4 August 22nd, 2016 11:12 AM
06 Eclipse 2.4 Headlight Issue F4iGirl02 Problem Reports 7 March 10th, 2015 04:58 PM
