I have a question when engine is not warmed up, high RPM at idling - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > General > 2000-2005 Eclipse (General 3G)
2000-2005 Eclipse (General 3G) General discussion and information about 2000~2005 (3rd Generation) Eclipse
Old May 14th, 2015, 08:22 PM   #1 (permalink)
dereklin1992@yahoo.com is on a distinguished road
Question when engine is not warmed up, high RPM at idling
hi, everyone!! I have a mitsubishi eclipse 2002 gt 3.0L v6 automatic . recently i noticed that my car is high on RPM when the engine is not warmed up(the temparature is about 70F), the RPM is about 1600 at idling when i start up the car, then after about 5 minutes of driving, it goes down about 800 RPM at idling. and i noticed that when the engine is not warmed up, at idling, my car would switch gear even i didn't hit the gas petal. the speed can go up to 20 Miles per hour at idling. everything is not normal.. I have 2 codes in my car, i thought it might have been the egr code causing this problem. there are the 2 codes. 1. egr valve curcuit malfunction 2. evap small leak and i have replaced the egr valve solenoid, but the code is still there, i wanted to take off my egr valve to replace it, but the bolt heads that connect the valve to the car are damaged, because they got stack to the car, and i used the screwdriver, couldn't take them off, and ruined them. And also I have replaced 2 of my oxygen sensor, front upstream and rear upstream.(bank1 sensor1 and bank2 sensor1) anybody knows what cause this problem???
dereklin1992@yahoo.com is offline   Reply With Quote Quick reply to this message
Old June 7th, 2015, 04:27 PM   #2 (permalink)
Wow!! didn't know this was sitting for so long, sorry.
Need to what the codes are to help you.
The small evap leak is more then likely your gas cap.
The bad screws, they do have tools to remove them, but you must be very careful when removing them not to damage them any more. Try Sears, they have some good removal tools.
2002, 600, art, automatic, car, codes, eclipse, eclipse 2002, engine, front, gas, gear, leak, miles, mitsubishi, mitsubishi eclipse, oxygen, problem, rear, sensor, speed, start, start up, switch, valve
Question: elipse 2002 gt 3.0L v6 high RPM when engine is cold, stall at idle [email protected] 2000-2005 Eclipse (General 3G) 1 August 4th, 2015 10:59 AM
gs hydrolocked engine calitin Problem Reports 36 February 28th, 2015 12:12 PM
Engine "bucks" when accellerating Jerry O Problem Reports 2 January 16th, 2015 07:54 AM
2006 eclipse engine shaking, smell of burnt, and wants to stall Nayla Problem Reports 3 August 9th, 2014 09:29 AM
