Got a used 07 SE! What maintenance to check on, and how to replace vent fins? - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old December 26th, 2016, 09:45 PM   #1 (permalink)
Vehicle: 2007 Eclipse SE
imranh101 is on a distinguished road
So I picked this car up today at a great price and in great condition. It's an 07 SE Automatic w/ the Rockford Fosgate sound system.
First thing it has 150k on it, what maintanence should I do first and foremost?
Previous owner was very trustworthy and honest, said "The dealer I bought it form said they did plugs and some other stuff, but they never provided me any paperwork to prove it so take that as you will", so that stuff may be done a couple thousand miles ago, I will be checking the plugs to see if they look fairly new this weekend.
Guy planned on doing an oil change this weekend if it hadn't sold yet, already had filter and full synthetic oil. Threw them in with the purchase. I'll be doing the change this weekend.
Has a brand new interstate battery from CostCo, and the Windshield is also brand new, with paperwork to prove and a lifetime warranty!
So now I ask; what first things should I check on maintanence-wise? Will have a few hundred bucks after the purcahse, not stacked on cash, but enough to do some basics.
Other than that the car is in fantastic condition inside and out. Only two issues to note; one the two center air vents, the fins are a bit messed up and need replacing. A bit of early ebay and google searching didnt find much on how to replace them, and where to buy replacements.
The other issue is the maplights on the rearview mirror are not working. The mirror has power as the auto-tilt function is working, but the lights are not.
One other thing is that there is a fair amount of road noise when in the cabin, and I'm just wondering if there is an easy way to cut down on it. I figure the best way will be some sound deadening material like Damplifier but just wondering if there is any other way.
Otherwise I'm glad to join this community and love the car already!
imranh101 is offline   Reply With Quote Quick reply to this message
Old December 27th, 2016, 01:04 AM   #2 (permalink)
Welcome to the club
If the timing belt hasn't been done, it's overdue
Is it the 4 or 6 cyl? Depending on area and year it seems both were offered as the SE. if it's the 4 cyl, do the balance shaft belt too while you're in there.
For the center vents, you can actually just pull the radio faceplate straight off. The first 2 pictures in my guide here will show you how it comes off. It's really simple.
https://club4g.org/board/do-yourself-...ake-cable.html
The vents themselves are held in by 3 clips each. It's possible however that someone was playing around and just unclipped the blades from the arm. I've done that to mine before while it was sitting in my back seat doing other work. That $0 fix is worth looking into.
Road noise will be had depending on the tire selection due to our minimal sound insulation. This is all we have inside the doors
and when I had my dashboard out I don't recall any in there.
Check for cupping on the tires. That could cause excessive noise, and indicate a bad strut.
Old December 27th, 2016, 01:21 AM   #3 (permalink)
4GECLIPSE27's Avatar
Vehicle: 2006 Eclipse GT/SE
4GECLIPSE27 will become famous soon enough
Welcome!
First question, you have an SE which stands for special edition, there are I4 and V6 versions of the SE, which drive-train do you have?
As for maintenance, things like spark plugs, water pump, thermostat, timing belt, CV axles, suspension bushings, brake rotors/pads, exhaust manifolds (V6), etc. will need replaced if not done already.
I have a 06 V6 and have done those things to mine thus far.
Some of the problems like the rear view mirror is actually a common problem for our cars and has to do with cracked solder joints. I haven't gotten to fixing mine yet, but there is a thread around the DIY section that shows what needs fixed. https://club4g.org/board/electronics/...irror-fix.html
One of my fins on my AC vents is also broken, but haven't had time to find another. Best option is to find one off a junker somewhere.
Dynamat in places of the car can reduce some vibrations, but is costly to do right in my opinion.
Other problems that our specific to our cars include:
1. The door handles can break at some point if used quite a bit. There are aluminum replacements that one of the members sells. 2006-2012 ECLIPSE MITSUBISHI PULL DOOR HANDLE | eBay
2. The gas cap sometimes gets corroded and fades so people either paint it or sand it and put clear coat on it. Or plasti-dip for easiness. https://club4g.org/board/maintenance/...ap-cancer.html
3. The interior dash at some point might start to raise because the glue has failed due to expansion and contraction from being heated and cooled. https://club4g.org/board/problem-repo...agra-dash.html
There are other things with this car as well, but every car has its quirks.
There is good information in the DIY sections for getting started fixing these cars. Do It Yourself Guides (Howto) - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
4GECLIPSE27 is offline   Reply With Quote Quick reply to this message
Old December 27th, 2016, 02:00 AM   #4 (permalink)
Thanks for all the info! Didn't realize the SE came in both the I4 and V6, mine is the I4.
Will def look into fixing the solder joint for the maplights. I'm quite handy with a soldering iron so shouldn't be too hard for me. I did check Pick n Pull and not seeing any G4 eclipses, but oh well. I'll keep an eye on em to see if I get lucky.
And yea I thought about Dynamat-ing but like you said, stuff is super expensive so I dunno if I'm gonna go forward with it or not.
Def noticed the gas cap stuff on mine and will probs fix that as well.
Thanks again for all the info and I'm happy to have found a new home in this forum
Old December 27th, 2016, 06:30 PM   #5 (permalink)
wingo171's Avatar
Vehicle: 08 GT SE and 91 3kgt VR4
wingo171 is a jewel in the roughwingo171 is a jewel in the rough
I will be posting a parts car once I receive the vehicle in. A 2008 GT SE Auto. Front end impact breaking the bumper, lip, and driver side front suspension and headlight. Parts are coming
wingo171 is offline   Reply With Quote Quick reply to this message
Old December 27th, 2016, 07:23 PM   #6 (permalink)
Awesome let me know how much you want for all 4 vents shipped once you get it, I'll take em!
automatic, battery, brand, brand new, buy, car, ebay, filter, fosgate, how to, life, noise, oil, oil change, plugs, power, rockford, rockford fosgate, sound, stuff, synthetic, synthetic oil, system, vents, warranty
