Noob - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old February 6th, 2020, 03:05 PM   #1 (permalink)
Eclipse718 is on a distinguished road
Noob
I have a 09 eclipse gs. Is there a site where I can find a turbo kit for my four-cylinder fourth GEN eclipse?
So not have to get it from eBay which everyone says is bad.
Also what can I do to my Engine to increase performance?
I’ve updated the cylinders exhaust suspension and added an cold intake. Anything else I can do?
I wanna make sure when I add a turbo I don’t blow my engine l!!!
Eclipse718 is offline   Reply With Quote Quick reply to this message
Old February 6th, 2020, 04:49 PM   #2 (permalink)
eBay doesn't sell a turbo kit for this car. There is no actual turbo kit available yet, I'm working on one though. If you'd like to buy parts loose and not as a kit, I can supply turbo manifolds, turbos, wastegates, boost controllers, injectors, etc. It won't all bolt together to your OEM setup, but it's not hard to make it work
I currently sell engine block build kits with pistons, rods, and bearings though, that'll support a high power turbo GS.
I don't know what updated cylinders are, but an underdrive pulley, and a tune will be your biggest power gains available to the GS before boosting. As for safe power, a tune is ALWAYS needed to make safe power. Without one, you can not run even 1psi of boost, as the ECU can not monitor for boost
Old February 6th, 2020, 06:48 PM   #3 (permalink)
eBay does tho.
And thx do u have an email or instagram or website so I can check it out.
Forgive me I’m just learning about cars so I don’t understand exactly which parts you were talking about.
I put stainless steel headers, Catback exhaust and cold air intake breaks rims tires and coilovers
Also just cause it was a used car new battery t belt air compressor
I do know about a tune I haven’t yet tho
Old February 6th, 2020, 07:58 PM   #4 (permalink)
Gamer
cmturner's Avatar
Trust me when I say it and others will say it too, you do not want a ebay turbo Kit, it will not be a plug and play, and will be the cheapest crap possible.
Turbo alone should be more then what those whole kits are selling for.
You will have to do a custom build, hardest part is finding a good exhaust manifold, after that it's piecing together everything,
My turbo setup all together was about $2500
https://club4g.org/board/members-ride...ners-ride.html
Old February 6th, 2020, 09:36 PM   #5 (permalink)
Thank u both a lot of good info
Old February 6th, 2020, 09:36 PM   #6 (permalink)
None of those turbo kits include the manifold, which is the reason why there is no eBay turbo kit.
I'm about $2500 into my current turbo setup right now as well, but I made my own manifold, downpipe, did custom intake piping, etc. No kits, which cut down on costs.
I can get you nearly everything you need. The things I won't supply, you can buy at a local hardware store cheaply, and auto shop cheaply. I also suggest an eBay intercooler piping kit and intercooler rather than what I would supply you with, as I've tested them to 35psi and know they're fine for that (haven't tested higher). 35psi on a proper sized setup isn't going to be less than 600whp, more around 800-900whp if you do it fancy.
I don't have an exact website that shows a list of parts, but I could make something up if you named what parts you're looking for, or just want me to shove a big list in front of you
