P0335 - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old March 31st, 2020, 12:40 PM   #1 (permalink)
Salo_'s Avatar
Salo_ is on a distinguished road
P0335
I tired starting my car and it wouldn’t start till I jumped it but then the code came up. I was looking for some advice on it because the previous owner did a timing belt change at 125K and I’m at 183k. But this morning i started up and it was fine then I was checked the code but then I sat in the car researching the code and now the car doesn’t start or turn over.
Salo_ is offline   Reply With Quote Quick reply to this message
Old March 31st, 2020, 05:36 PM   #2 (permalink)
Is your battery voltage low? At low voltage it could trigger the code.
Otherwise, if your timing is good (check the marks), replacing the sensor is super simple
Old March 31st, 2020, 06:23 PM   #3 (permalink)
There was a ECU/PCM firmware calibration update for this code from Mitsubishi for this code being thrown falsely
I know it came up on my car when my car wouldn't start when the starter went out
It’s a crank (or was it cam?) sensor code failure but it basically gets thrown every time there’s a no crank for whatever reason, starter, timing belt, low battery, anything
Honestly I’d check the battery first, how old is yours?
pcfreak4 is online now   Reply With Quote Quick reply to this message
Old April 1st, 2020, 01:43 PM   #4 (permalink)
Salo_'s Avatar
The voltage is at 12. But I’m not sure about the age of the battery because this May it’s going be 2 years of me owning the eclipse.
Old April 1st, 2020, 01:44 PM   #5 (permalink)
Salo_'s Avatar
The code reads it’s a crankshaft sensor.
Old April 1st, 2020, 06:11 PM   #6 (permalink)
That’s the voltage at rest? Voltage during load/cranking is important too
12.6 should be full charge, 12.0 is actually getting half empty believe it or not, a 12v lead acid car battery has 6 1.2v cells in it making 12.6v full
Have that battery load tested with a load tester tool or just replace the thing
Old April 2nd, 2020, 04:41 PM   #7 (permalink)
Salo_'s Avatar
Yea at rest it was 12.
Old April 2nd, 2020, 07:16 PM   #8 (permalink)
Get it load tested if possible
Old April 28th, 2020, 09:43 AM   #9 (permalink)
Salo_'s Avatar
UPDATE:
One day I went to see if my eclipse would start and it had no power so dead battery. Took the battery out and got it charged at autozone for free but they said the battery was no good. But I reinstalled it and my eclipse started right back up like a dream. Went to Walmart got a new 130 dollar battery so me and my eclipse are back on the road. So in the end it was the battery for throwing the code of P0335. Thanks for the help.
Old April 28th, 2020, 10:21 AM   #10 (permalink)
Yup like I think I said before, my car threw P0335 for a bad starter
It gets falsely set anytime there’s a no crank duration, although it’s for the crank sensor it might not be the crank sensor
Mitsubishi had ECU PCM updates to help fix this issue but it’s not a big deal
Glad u got it fixed
