Tricking Evap system with resistor - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old May 15th, 2020, 06:44 PM   #1 (permalink)
So the evap system to the ECU consists of the purge solenoid, the vent solenoid, and the pressure sensor on the tank, as well as the fuel level sensors in the tank
To emulate the correct pressure the ECU would like to see, I’m thinking of emulating the pressure sensor the the ECU’s wiring to the sensor with a resistor, or at least make the test never run so that the check engine light never comes on for this issue anymore but I’m ok with the evap monitor still not being ready
pcfreak4 is online now   Reply With Quote Quick reply to this message
Old May 15th, 2020, 07:01 PM   #2 (permalink)
FSM says one of the requirements for the test to begin is that the pressure sensor needs to be between 1-4v, looks like 3 wires to the sensor are a 5v power wire, a ground, and an output wire to the PCM (probably 0-5v based on its reading), so jumping a wire from the 5v power wire to the wire going to the PCM and the PCM seeing a 5v constant would prevent the test from running?
Old May 15th, 2020, 07:09 PM   #3 (permalink)
Yellow-red is 5v positive, brown is ground, red-green is output signal
So jumping yellow-red to red-green wires should give the PCM a constant 5v signal from this pressure sensor, still within the range of the sensor giving output to the PCM and not blowing the PCM up or anything, and preventing the EVAP monitor from running the test as it's out of the 1-4v range?
Or perhaps using a resistor to get the output to a constant voltage below 1v would be better
Old May 16th, 2020, 09:08 AM   #4 (permalink)
A constant voltage below 1 would also be 0 in theory. Unplugged. But I suspect that would throw a different code. And constant 5v returning to the ecu may also throw a code of a different sort.
You can try it though.
Old May 16th, 2020, 10:18 AM   #5 (permalink)
The code criteria for any of the evap code and pressure sensor checks consist of checking if the sensor is greater than 0.2 and less than 4.9, but the P0455 check won't run unless the ECU is within 1-4v, so having the output at 0.3-0.9v or 5v should prevent the other codes from throwing and prevent the evap check from running
