4g69 2007 eclipse running on 2 cylinders - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old August 11th, 2020, 08:16 AM   #1 (permalink)
LadBuck is on a distinguished road
I have a 2007 eclipse 2.4 4cyl. Car ran great before this. Problems began when timing belt gave out while driving. Did compression test and found 6 intake valves bent. Went and had head rebuilt at a shop and then I went and put everything back together, aligned all the timing marks to tdc. I went to fire up the car and it started and ran at idle roughly and sounded funning like it was missing. A couple codes came up like cam position but I believe it was just because it was unplugged. I cleared the codes and it didnt come back. So I did some checking and found that cylinders 1 and 3 are working and firing but cylinders 2 and 4 are not running. I have double checked everything but cannot find any problems as to why just those 2 cylinders wont fire. The car will run and drive but barely. After a few minutes of driving the car throws "system to lean codes" which I would imagine is from the 2 cylinders not firing.
I also rechecked the compression on all 4 cylinders and all are at 180psi.
Has anyone ever encountered this? Any helps is very much appreciated.
LadBuck is offline   Reply With Quote Quick reply to this message
Old August 11th, 2020, 10:43 AM   #2 (permalink)
How do u know those cylinders aren’t firing?
Old August 11th, 2020, 12:15 PM   #3 (permalink)
I pulled the spark plug and the injector to both cylinders 2 and 4 and the engine never changes its beat but when I pull the other cylinder 1 and 3 plugs the engine dies almost immediately
Old August 11th, 2020, 01:17 PM   #4 (permalink)
Are you getting misfire codes
Old August 11th, 2020, 01:54 PM   #5 (permalink)
No missfire codes
Old August 11th, 2020, 07:55 PM   #6 (permalink)
Not even a P0300? U should get that right away if u have any misfire, the specific cylinder codes take a little while because the ECU has to take in calculations from the crank sensor to determine which cylinders are misfiring
Old August 12th, 2020, 06:32 PM   #7 (permalink)
I completely agree and with the trouble code problem, I'm not sure why it wouldn't throw a code especially when the engine was rotating as rough as it was.
Also an update I found the problem. Cylinders 2 and 4 coil packs were bad.
I'm not sure how this happened. All factory coil packs and none were bad at the time of the timing belt/head rebuild. But I swapped coil packs between cylinders and the problem followed the coil pack but still never gave a misfire code or any code at all. So I bought 2 new ones and engine runs great now.
Old August 12th, 2020, 07:45 PM   #8 (permalink)
Good to hear
Old August 12th, 2020, 07:46 PM   #9 (permalink)
(Fixed)4g69 2007 eclipse running on 2 cylinders
Thank you for the help!
