I have a question 2.4L 5speed shuts down while driving. - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old May 22nd, 2020, 04:26 PM   #1 (permalink)
Albert1984 is on a distinguished road
So here's the lowdown:
I have changed the camshaft sensor/crankshaft sensor, thermostat, coils, spark plugs, coolant, cleaned MAF, cleaned throttle body, put new clutch and throwout bearing. Oil is topped off good and no real leaks.
The car drives real good for about fifteen minutes and then at a full stop dies and doesn't want to start back up, unless I let it sit for about 20 minutes stranded. The car will shoot P0340 codes for cam and crank shaft sensors, and then another for random misfires detected. I don't see any bad wires but ill have to strip it down and take a closer look at the wiring. I'm just at a loss for words, I've replaced both sensors and I'm still getting stalling and rough starts, then the cam and crank shaft codes??? Any ideas and help will be appreciated...thanks!
Albert1984 is offline   Reply With Quote Quick reply to this message
Old May 22nd, 2020, 06:19 PM   #2 (permalink)
Vehicle: 07 eclipse gs turbo
Jayallen is on a distinguished road
When I did my timing belt. I got the code for the crankshaft sensor. I would start my car before I put everything back together then after I had all back together the car wouldn't start. It turned out to be a loose wire in the harness. So when I got my car to start I pulled on all the wires until I found the lose connection in the wire harness to the crank sensor I did this by having the car running. The loose wire pulled right out.
Sent from my SM-G960U using Tapatalk
Jayallen is offline   Reply With Quote Quick reply to this message
Old May 22nd, 2020, 06:30 PM   #3 (permalink)
hey thanks for the input, I will try the loose wire technique, but the car will either die at a full stop(like coming to a stop sign) or will start jerking really bad and then die suddenly...I should've mentioned the second way it died, totally forgot.
Old May 22nd, 2020, 06:36 PM   #4 (permalink)
Battery connection dirty?
Relay overheating?
Lower timing cover damaged? (Has the crank sensor plug)
Knockoff Fastworks tune, not from Fastworks?
Immobilizer?
Old May 22nd, 2020, 11:21 PM   #5 (permalink)
140whp+15.72%= 162hp
Sparda D'Mon's Avatar
Vehicle: 2007 Eclipse GS 2.4
Relay overheating?
Immobilizer?
Knockoff Fastworks tune? How is that possible? You wont mention something unless you suspect something.
Old May 23rd, 2020, 05:17 AM   #6 (permalink)
Usually an immobilized can’t shut a car down once it’s started for safety reasons
2.4l, art, back, bad, bearing, body, car, clutch, codes, coils, coolant, dies, good, loss, maf, plugs, random, rip, sensors, spark, speed, start, throttle, throttle body, wiring
