I have a question 4G69 Engine Overhaul Efficacy - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old May 25th, 2020, 04:34 PM   #1 (permalink)
GotWeez's Avatar
GotWeez is on a distinguished road
Recently my 4G69 equipped 2009 Eclipse GS 2.4 has started throwing an oil pressure light at idle speeds (600-800RPMs) when up to temperature.
She's 189,000 miles old, and has given me absolutely no mechanical woes; I'm the second owner, purchased in 2014, and have kept her bone stock with oil changes at 4.5k intervals on semi or full synthetic oil.
Second pic is underside of block, by oil pan. She hasn't even gone weepy.
The car will likely need a new oil pump/front timing assembly (MN137803), new timing belts, etc.
From an overall cost perspective, is it worth it to keep this car in daily service and repair it in the engine bay, purchase a second vehicle and garage this one to pull and rebuild the engine, or should I clean her up and sell her to her final owner?
GotWeez is offline   Reply With Quote Quick reply to this message
Old May 25th, 2020, 04:54 PM   #2 (permalink)
Try a new pressure sensor first
It looks great to me
Old May 25th, 2020, 09:44 PM   #3 (permalink)
The fact that it's at idle HEAVILY supports that the sensor isn't the issue. Usually that's a sign of worn bearings or a leaking pump (internally). But hey, it's worth a shot at the price.
If you rebuild the block, you'll see quite a lot more use from the car. They're a very stiff chassis, and will last a long time maintained. The Bay looks like it's incredibly clean, and is in better shape than any in Canada I've ever seen
Old May 26th, 2020, 12:09 PM   #4 (permalink)
140whp+15.72%= 162hp
Sparda D'Mon's Avatar
Vehicle: 2007 Eclipse GS 2.4
Anybody else wants to point out that he should stick to full Synth instead of going bk and forth from semi to full synth? Or is he ok?
Old May 26th, 2020, 12:18 PM   #5 (permalink)
You ultimately should pick one and stick with it, if you’re gonna go synthetic, stay with synthetic, some would argue that sticking to the exact same one too is advisable due to different additive packs getting mixed if u switch brand or type
I use Castrol Edge 5w20 in my eclipse if anybody cares
Old May 26th, 2020, 02:14 PM   #6 (permalink)
I cared before I started rebuilding motors. Now, I've found that synthetic just slows down wear due to being more slippery
Old May 26th, 2020, 04:20 PM   #7 (permalink)
GotWeez's Avatar
So as far as the blend of oil, I'm not as concerned as the oil changes are complete flushes. Typically, I use the Castrol GTX high mileage Syn.
I removed the oil pressure switch and found that at cold idle had about 25-30psi and idling at temperature with 18-22psi. Spec should be around 4.5 psi.
Replaced switch, waiting for thread sealant to cure. Will attempt to replicate symptoms. Next step will be a 10W-30 to help keep things sealed up better at temperature.
A little baffled as to the high pressure reading on dial. Any thoughts?
Old May 26th, 2020, 09:24 PM   #8 (permalink)
Weird. I only do about 10psi hot idle on 15w-40 on a freshly built motor. When coolant first hits 185f, the oil is only about 120f. It takes quite a while to get the oil up to or past 185f where the pressure sits around 10.
Old June 3rd, 2020, 07:22 PM   #9 (permalink)
Fizzix's Avatar
Vehicle: 09 Solar(Y19) Eclipse GS
Fizzix will become famous soon enough
If you're getting 25-30/18-22 psi cold/hot @ idle, I'd say those are excellent numbers for an engine with that kind of mileage/age. A good rule of thumb I usually go by for oil pressure is ~10 psi per 1000 rpm when hot.
Do you know the actual oil temp when you took those oil pressure readings? On a cold engine, coolant temps typically rise a lot faster than oil temps. That might explain the higher than normal pressure reading.
Also, there isn't a problem mixing semi/full synthetic or varying service spec oils over the life of the engine. One of the SAE specs that is part of the API service rating classification is that the newest spec is backwards compatible with previous ones.
API Engine Oil Classification
https://www.api.org/products-and-ser...oil-categories
Fizzix is offline   Reply With Quote Quick reply to this message
Old June 6th, 2020, 10:26 AM   #10 (permalink)
GotWeez's Avatar
No, I didn't measure the oil temperature directly, I just ran the motor for about as long as it took for the pressure indicator to light up, about 20-30 minutes.
When I replaced the oil pressure switch, I did note oil present inside of the electrical connector. Since replacing it and switching oil grades, I haven't had any indicators light up, so I'm thinking it was just the switch. For now, I've coated my replacement pump in oil for storage and will wait and see what happens.
