Stayer. Camshaft kit 6G75 MIVEC - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old June 12th, 2018, 10:45 AM   #1 (permalink)
stayer's Avatar
Vehicle: 2010 Galant9G 4G69MIVEC
stayer is a jewel in the roughstayer is a jewel in the rough
Hi friends!
Earlier I announced a topic about the kit camshaft for 6G75. It's time to do this for the 6G75. As always, I try to explain the principle of operation. It's hard for me to explain in English. But I will try to make you understand me.
stayer is offline   Reply With Quote Quick reply to this message
Old June 12th, 2018, 10:46 AM   #2 (permalink)
stayer's Avatar
So. The 6G75 engine has a system of MIVEC, similar to 4G69. Moreover, this system operates on the principle of switching types of Cams of the camshaft. There is also a system with rotation of the camshaft (for example Evo 9). In this system up to 3500 rpm working one type of cams. After 3500 rpm the work enters the other Cam.
Look at the picture. Cam A - works after 3500 rpm (intake). Cam B - works on exhaust. Cam С - works up to 3500 rpm (intake).
Old June 12th, 2018, 10:55 AM   #3 (permalink)
stayer's Avatar
In the engine is like two engines. To 3500 rpm economical with low frictional resistance. After 3500 rpm the more powerful and torquey.
What do I do?
Produced completion of Cam A. Now I'll explain the principle.
Look at the picture. On a special machine, decreases the base radius of the Cam. This increases valve lift and the width of the phase. Thus, up to 3500 rpm, the engine will remain as before. And after 3500 rpm will be more powerful.
Old June 12th, 2018, 10:57 AM   #4 (permalink)
stayer's Avatar
Usually, this revision gives a 12-15% gain on top. I do it at an aircraft factory in the city of Perm. But that's not all. Also need to modify the rockers. Working on this Cam. If at the end of the rocker was the adjustment screw, then you can just adjust. However, the rocker mivec does not contain the adjusting screw.
After you did the regrinding of the camshaft and its base radius becomes smaller. Therefore, under the rocker will appear a gap.
Therefore, it is necessary to make a thicker roller. The wheel needs to be thicker for the same size, how much reduced base radius.
Old June 12th, 2018, 11:03 AM   #5 (permalink)
stayer's Avatar
One of our member is from Chile (Alonso Escobar), he sent me his camshafts and 6 MIVEC rockers.
Old June 12th, 2018, 11:10 AM   #6 (permalink)
stayer's Avatar
it is necessary to disassemble the rockers. This is a needle bearing.
Old June 12th, 2018, 11:18 AM   #7 (permalink)
stayer's Avatar
Further, at the aircraft factory in the city of Perm, made rollers of larger diameter.
Camshafts are ground off Cams A. (-1.7 mm diameter). Accordingly, the rollers are longer than stock (+1.7 mm diameter)
left is stock, right is new.
Old June 12th, 2018, 11:26 AM   #8 (permalink)
stayer's Avatar
I originally thought that the duration of the opening of the 6g75 camshafts is the same as the 4G69. However, when I measured the shafts, I saw a difference.
duration 4G69 - 274 degrees
duration 6G75 - 264 degrees
Therefore, after the regrinding, the result is slightly different.
4G69 - 296 degrees
6G75 - 286 degrees
Old June 12th, 2018, 11:30 AM   #9 (permalink)
stayer's Avatar
the whole set after Assembly.
Now this package is going to Chile. We'll wait for Alonso to receive and install new parts on his engine. After that you will configure on the dyno. You'll see what a raise the camshafts give. That's all.
Old June 12th, 2018, 12:45 PM   #10 (permalink)
Vehicle: 2011/Eclipse/GT
Charmindx is on a distinguished road
Can't Wait for Results. Any idea on costs?
Charmindx is offline   Reply With Quote Quick reply to this message
Old June 12th, 2018, 12:58 PM   #11 (permalink)
stayer's Avatar
the price is$ 100 for 1 cylinder. However, I want to note that it will be necessary to reflash the ECU. Reflashing is not included.
Old June 12th, 2018, 01:17 PM   #12 (permalink)
stayer's Avatar
I did before the Cam for other cars. Power increase is usually 12-15 %. I expect to get at least 35-38 HP for 6G75
Old June 12th, 2018, 08:51 PM   #13 (permalink)
Plain Jane's Avatar
Plain Jane is a jewel in the roughPlain Jane is a jewel in the rough
Very interesting. I will be watching this closely.
'07 GT build thread - 280whp, 254wtq
Plain Jane is offline   Reply With Quote Quick reply to this message
Old June 13th, 2018, 03:17 PM   #14 (permalink)
Orion3003 is on a distinguished road
shut up and take my money already!
I'll definitely be watching this closely as well.
Thanks for the thread.
Orion3003 is offline   Reply With Quote Quick reply to this message
Old June 16th, 2018, 01:37 AM   #15 (permalink)
SuperEvilnine's Avatar
Vehicle: 2009 GT
SuperEvilnine will become famous soon enough
Wow, maybe this should be my first engine mod..
Sent from my LGLS991 using Tapatalk
SuperEvilnine is offline   Reply With Quote Quick reply to this message
Old July 17th, 2018, 07:07 PM   #16 (permalink)
any updates on this stayer?
Old July 17th, 2018, 11:15 PM   #17 (permalink)
stayer's Avatar
He received a parcel in his country. But not yet assembled the engine. Waiting for Assembly.
Old July 17th, 2018, 11:55 PM   #18 (permalink)
Got it! Thanks man
Old July 19th, 2018, 10:10 AM   #19 (permalink)
Plain Jane's Avatar
Will these behave like normal cams below MIVEC? Would love a set but not sure if willing to sacrifice my daily driveabilty for the extra power.
Old July 19th, 2018, 11:28 PM   #20 (permalink)
stayer's Avatar
The whole point of this revision, to raise the power and torque in the high side of the speed (RPM). Before the MIVEC rockers start working, everything works as before. When the MIVEC system is turned on, more air will now be released into the combustion chamber. Due to the fact that a higher duration. And higher the valve lift.
Of course, everyone decides whether to do something with your car. It's actually enough to drive a stock car.
Old July 23rd, 2018, 11:32 AM   #21 (permalink)
Plain Jane's Avatar
Best of both worlds, fantastic
Old August 2nd, 2018, 05:12 PM   #22 (permalink)
Are you gonna go through with it?
Old August 23rd, 2018, 08:32 PM   #23 (permalink)
Vehicle: 2008 Eclispe GT 6MT
#TampaEclipse is on a distinguished road
I'll be watching this too. How long would it take you to do this job once you recieve the cams and rockers? And do I understand correctly that to do both cams and all six rockers would cost a total of $600 ($100 per cylinder x 6)?
#TampaEclipse is offline   Reply With Quote Quick reply to this message
Old August 23rd, 2018, 09:28 PM   #24 (permalink)
stayer's Avatar
Yes, the job is $ 600. After receiving, it takes about 2 weeks. It depends on the workload of production. Sometimes a little faster, sometimes a little longer.
Old August 26th, 2018, 05:47 PM   #25 (permalink)
Beastmobrandon's Avatar
Beastmobrandon is on a distinguished road
Are there any dynos done with these new came anywhere to show power increase? I'm definitely interested and I know my friend has been talking about doing it. Just wondering how much of an increase there will be on the top end
Beastmobrandon is offline   Reply With Quote Quick reply to this message
Old August 26th, 2018, 10:36 PM   #26 (permalink)
Sup Brandon!
Here's what Stayer wrote earlier...
"I did before the Cam for other cars. Power increase is usually 12-15 %. I expect to get at least 35-38 HP for 6G75"
No dynos yet. He's still waiting for the guy in chile to install and get his GT on the dyno so that he can create the tune for the car. These cams won't work without the tune so I'm just waiting for that before I send my cams over
Old January 11th, 2019, 04:09 PM   #27 (permalink)
The Evil Wizard
Vehicle: 94 Galant GS
majin is a jewel in the roughmajin is a jewel in the rough
still waiting...
Long time Lurker
majin is offline   Reply With Quote Quick reply to this message
Old September 24th, 2019, 07:19 AM   #28 (permalink)
4g_jayson's Avatar
4g_jayson is on a distinguished road
Anything on this yet??? I’m VERY VERY INTERESTED, I want to unlock the TRUE potential of this motor, I currently have bolt ONS, but plan on PnP the upper and lower plenum, increasing the stock 65mm throttle body to a 67mm, e85 fuel pump and injectors. & Hopefully this works out , if so I’m doing this next next 😂
4g_jayson is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2020, 12:20 PM   #29 (permalink)
L8nyght is on a distinguished road
It’s now 2020, what’s the word on this?
L8nyght is offline   Reply With Quote Quick reply to this message
Old March 15th, 2020, 12:48 PM   #30 (permalink)
4g_jayson's Avatar
I was told Delta Camshafts can regrind our cams, we just have to send them our out.
6g75, kit, mivec, stayer
Stayer. Camshaft kit 4G69. stayer 4G Eclipse GS/SE Specific 57 September 25th, 2020 10:28 AM
FS: 2007 Spyder GS with 6G75 Swap with SDS Kit trevroar Cars For Sale/Wanted 8 October 29th, 2017 02:33 PM
2003 Eclipse GT - 3.8L 6G75 MIVEC SPD_FRK Member's Rides 13 April 11th, 2016 10:52 AM
Wanted 3.8L Mivec 6G75 fast3/s Automotive For Sale/Wanted 8 April 20th, 2015 08:06 PM
what kit of spring & retairners are compatible in the 3.8 mivec heads Potencia Performance Forced Induction & Nitrous 1 October 25th, 2014 12:22 PM
