Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority (https://www.club4g.org/board/)
-   Member's Videos (https://www.club4g.org/board/members-videos/)
-   -   How to turn a rusty exhaust manifold into a trick header . L52 engine header fabricat (https://www.club4g.org/board/members-videos/120547-how-turn-rusty-exhaust-manifold-into-trick-header-l52-engine-header-fabricat.html)
n-e-o May 27th, 2020 05:15 PM
In order to rebuild an old, rusty motor, you need to go through every single component. As a matter of fact, you'd be better off replacing factory parts with aftermarket goodies. On a Hummer H3, replacing the stock cast iron exhaust manifold is a necessity, due to it being prone to cracking. I've made a high-flow replacement manifold with equal length runners using AISI 304 stainless steel. Each runner is 42.4 mm wide, wall thickness is 3 mm, while the 5-1 merge collector is 60 cm long. These specs allow for increasing engine efficiency and improving exhaust gas flow out of the cylinders on this inline-5 L52 Vortec 3500 GM's engine. This exhaust manifold is durable enough to allow for installing a turbocharger. The manifold was made using a TIG-welder fed with argon. This timelapse video shows the entire process of how the exhaust header was made.
<iframe width="560" height="315" src="https://www.youtube.com/embed/EVJOtiWuQKA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
swiger August 21st, 2020 08:29 AM
Wow, this was totally what I needed. I wish I had seen this before buying a new exhaust.
