Idle Surging problems - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old June 2nd, 2020, 03:09 PM   #1 (permalink)
XXJJ11 is on a distinguished road
I got a 07 Eclipse GS and as of now it is having a rough idle and a idle surge, new injectors, EGR valve, spark plugs, and coils have been put on it. But once you start it up it will start to drop in rpms and bounce. And as of recently it says it has ran lean, if someone could help, that’d be appreciated a lot
XXJJ11 is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2020, 04:01 PM   #2 (permalink)
Well, any codes?
pcfreak4 is online now   Reply With Quote Quick reply to this message
Old June 2nd, 2020, 04:06 PM   #3 (permalink)
Yes, a P0300 code and some P0171 codes
Old June 2nd, 2020, 09:01 PM   #4 (permalink)
Misfire and lean codes
Look for vacuum leaks, especially on your intake
So a P0300 is general misfire, either multiple cylinders that the computer can’t figure out yet which cylinders are misfiring or it hasn’t ran long enough to identify specific cylinders, I wouldn’t recommend running it like this
Check spark plugs, coil packs, oil leaking through valve cover gasket seals
What spark plugs did you put in it? NGK Laser Iridium OEM LZFR6AI?
Old June 3rd, 2020, 07:19 AM   #5 (permalink)
I put NGK iridiums in it and I will try that, thank you
Old June 3rd, 2020, 03:20 PM   #6 (permalink)
Laser Iridium 3656 LZFR6AI is stock, not Iridium IX
I’d lean to a lean condition causing the misfire though if it keeps happening with new plugs
Check your LTFT with a scan tool, if it’s pegged past -15% then you have a problem
Old June 3rd, 2020, 05:18 PM   #7 (permalink)
Alright, and is there a way to tell if it’s a disconnected hose that’s causing it to go lean or not?
Old June 3rd, 2020, 06:05 PM   #8 (permalink)
Smoke test, through the intake or vacuum line from the intake pipe, or through the brake booster
Old June 4th, 2020, 07:49 AM   #9 (permalink)
Or a pressure test. You can take a Schraeder valve and a plumbing cap, drill out a hole in the cap, pull the valve through, connect it to your intake pipe, and pressurize it with an air compressor. It'll hiss where the leaks are. Just pull the oil cap off first
