Code P0431 - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old June 29th, 2020, 05:19 PM   #1 (permalink)
Walketfretts's Avatar
Walketfretts is on a distinguished road
Code P0431
what does this mean? Is there much to worry about?
Walketfretts is offline   Reply With Quote Quick reply to this message
Old June 29th, 2020, 06:57 PM   #2 (permalink)
Bad catalytic converter in your exhaust
It could be very bad depending on how bad it gets
It’s clogged up and eventually once it clogs up too much your engine will lose serious power, possibly overheat, and the cat could break apart and get sucked back into your engine or shot further dow your exhaust getting stuck in the next cat
Old June 29th, 2020, 07:12 PM   #3 (permalink)
So to the shop it goes?
Old June 29th, 2020, 07:12 PM   #4 (permalink)
Is your car the 4cyl or 6cyl? Aftermarket exhaust headers? Tune? When were the O2 sensors replaced last?
Old June 29th, 2020, 07:14 PM   #5 (permalink)
How would I know which cat is bad?
Old June 29th, 2020, 07:15 PM   #6 (permalink)
4cyl SE, stock exhaust, stock tune, did a intake resonator delete and fuel bypass, O2 sensors were replaced about 5months ago i belive.
Old June 29th, 2020, 07:29 PM   #7 (permalink)
That’s a code for bank 2, but doesn’t matter, the whole manifold houses both pre cats
There is another fix but we aren’t allowed to discuss it legally
Fuel bypass?
U think they were replaced? Were they, or were they not?
Old June 29th, 2020, 07:41 PM   #8 (permalink)
Fuel bypass?
O2 sensor was replaced in January, i did not do a fuel bypass.
Old June 29th, 2020, 07:49 PM   #9 (permalink)
[QUOTE=Walketfretts;1917565]
Fuel bypass?
O2 sensor was replaced in January, i did not do a fuel bypass. I meant coolant bypass. Sorry
Old June 30th, 2020, 08:21 AM   #10 (permalink)
You’re gonna need a racing header from RRE with rear O2 spacers or a tune (these are in very limited or not even in production now), new manifold from Mitsubishi to stay road legal and not require a tune, or gut your current manifold and use rear O2 spacers or a tune
Don’t get one of those cheap eBay Chinese manifolds, they don’t have the correct front O2 bungs
One one of these options we can recommend for road legal emissions compliant use, replacing it with a brand new manifold with cats
Old June 30th, 2020, 10:04 AM   #11 (permalink)
Can you send me a link for the Headers?
Old June 30th, 2020, 11:23 AM   #12 (permalink)
Also what kind of O2 sensor spacer would I need?
Old June 30th, 2020, 12:00 PM   #13 (permalink)
http://roadraceengineering.com/blog/...eclipse_parts/
This comes with spacers, do not use spacers on your clogged manifold
Old June 30th, 2020, 12:35 PM   #14 (permalink)
Was just about to say I figured it out haha. Just put the order in for the manifold. Iv been reading the how to and doesn't seem too difficult for this car.
Old June 30th, 2020, 01:17 PM   #15 (permalink)
Only difficult part will be the stuck bolts, heat and PBBlaster will help
Make sure u clean the surface good and use a new gasket
Old July 3rd, 2020, 04:41 PM   #16 (permalink)
I shouldn't have jinxed it, won't be in until August, had the car in and I even saw for myself the exhaust manifold is cracked and not clogged, so I'm apperantly now on a waiting list with RRE because their metal factory is shut down cuz of Covid (southern California based). As to a temporary fix so I can at least safely get too and from work (15min drive) what should I do? I was gonna use the copper gasket I bought for the new part isntall.
Old July 3rd, 2020, 06:41 PM   #17 (permalink)
It’s cracked before the cat? Interesting, honestly not too sure why that’d happen, unless the cat was clogged and then caused so much back pressure that it forced the manifold to crack from pressure
To keep driving it? I’d just leave it cracked for now
Old July 7th, 2020, 04:07 AM   #18 (permalink)
For the headers, you did not get a check engine light after install? Do the spacers for the O2 sensors do their job properly?
Old July 7th, 2020, 04:47 AM   #19 (permalink)
The spacers are intermittent
They work decently but every now and again you might get a code for it, which you can try to adjust the hole in your spacers
The tune is nice because you just know that it’s taken care of for good
Old July 8th, 2020, 08:47 PM   #20 (permalink)
140whp+15.72%= 162hp
Sparda D'Mon's Avatar
Vehicle: 2007 Eclipse GS 2.4
Spacers never worked for me. They broke my sensors or maybe I did installing the spacers but Fastworks tune DID work. I had to replace my broken o2 sensors for it to work but now im happy with no SES light.
