Tach wire for turbosmart boost controller. - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old June 2nd, 2020, 02:08 PM   #1 (permalink)
Vehicle: 07 eclipse gs turbo
Jayallen is on a distinguished road
Anybody know which wire I can tap into for the tachometer for the boost controller? Pictures or a diagram would be great. Thanks
Sent from my SM-G960U using Tapatalk
Jayallen is offline   Reply With Quote Quick reply to this message
Old June 2nd, 2020, 04:01 PM   #2 (permalink)
Don’t think there is a tach wire, why would you need it for a boost controller?
Modern cars use timing and crank position sensor to determine RPM digitally
Old June 2nd, 2020, 04:19 PM   #3 (permalink)
Donít think there is a tach wire, why would you need it for a boost controller?
Boost correct function is use to reduce or eliminate boost drop off at high RPM. Wire is suppose to go to ecu.
Old June 2nd, 2020, 09:04 PM   #4 (permalink)
Boost drop off is pretty natural at higher RPMs
A manual boost controller is probably way easier to hook up for a car that was never boosted stock
Old June 3rd, 2020, 08:06 AM   #5 (permalink)
Nah, it actually can be fixed with electronic boost controllers to an extent, and I run an electronic boost controller on my Eclipse, and have ZERO desire to have used a manual controller. They are significantly worse in every way
Even wired up without the tach the electronic boost controller still wins.
There IS a wire somewhere that can be used, and I have the diagram somewhere buried in my emails. There's a company that does nitrous installs that found the wire to use for the RPM signal, and they connect nitrous controllers to it. It should work just the same for boost controllers. I was talking to them about it
UPDATE: They just used the crank signal wire at the ECU. Pin 103, green wire with red tracer. It'll give 2 pulses per rotation, same trigger wheel as a 4G63.
Old June 3rd, 2020, 04:45 PM   #6 (permalink)
https://evoscan.com/technical-vehicl...e-gt-gs-spyder found a link for our ecu pinout and what they are
Old June 10th, 2020, 07:25 PM   #7 (permalink)
Well I tried the 103 pin it works but you need to have a resistor on it otherwise your car won't start. For the 4g63 they recommend a 3.3k. Waiting on what resistor I need from turbosmart customer service.
boost, controller, pictures, wire
