Clicking - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old October 13th, 2018, 02:43 PM   #1 (permalink)
Vehicle: 2012 eclipse gs sport
kilala311 is on a distinguished road
Clicking
So I've seen only one post about this and I'm in school going for auto tech so I've asked my teacher about this , but when I turn at lower speeds there is a clicking from my back driver wheel. It also happens on smaller bumps. It doesnt happen all the time but I cant figure out what is causing it. I just got brand new tires last week and i think that's when it started
kilala311 is offline   Reply With Quote Quick reply to this message
Old October 13th, 2018, 06:42 PM   #2 (permalink)
NamelessFoe's Avatar
Vehicle: 2006/Eclipse/GS
NamelessFoe will become famous soon enough
sounds like ball joint to me. I'd jack the car up and see if the tire has any play in it.
NamelessFoe is offline   Reply With Quote Quick reply to this message
Old October 15th, 2018, 12:17 AM   #3 (permalink)
Already tried that. It only happens when I'm in like a parking lot or taking off , all the suspension doesnt have play , ball joint it fine wheel hub is fine. Doesnt make the noise when I have my foot on the break though
Old October 15th, 2018, 06:29 AM   #4 (permalink)
Joshinator99's Avatar
Vehicle: 2006 Eclipse GS
Joshinator99 is on a distinguished road
Hmmm, sway bar end link?
2017 Chevy Camaro SS A8 6.2L DI V8, Whipple supercharger, 95mm TB, 5 CAI, AWE Tuning dual 3 exhaust, DSX E85 kit, 3.5 GForce Al driveshaft, 608 WHP/610 WTQ, [email protected]
2019 Toyota Sequoia Limited A6 5.7L V8, 381 HP, 4WD, 20 wheels. Daily driver.
2018 Alfa Romeo Ti Sport Q4 A9 AWD, Carbon fiber driveshaft, adaptive suspension, 19s.
Joshinator99 is offline   Reply With Quote Quick reply to this message
Old October 15th, 2018, 09:30 AM   #5 (permalink)
ive had it lifted and checked the suspension and it all seems correct and alright, my teacher said it may be a brake pad walking or shifting. it started right after i put on tires and its on the side with a bent rim so that may be causing it as well
Old October 15th, 2018, 08:18 PM   #6 (permalink)
If you floor it and get a bad click, it could be your Trailing arms bushings, since flooring it would make the rear tires pull back as they start to move. But the clicking on bumps sounds like your ball joint has up and down play. Have you checked all your caliper bolts? guide pins and bracket bolts to see if they came loose? An end link would give you a clicking noise through everything the suspension hits.
Old October 18th, 2018, 10:21 AM   #7 (permalink)
i havent yet but i will thats a good idea we felt around and nothing felt loose but i will pull it apart and check
Old October 21st, 2018, 02:06 PM   #8 (permalink)
So I've tried tightening the caliper it isnt that and I'm at a complete loss
Old October 21st, 2018, 03:36 PM   #9 (permalink)
i would find a bumpy parking lot and have a friend walk next to the car on all sides to see if it''s actually coming from the rear or front. Weird to constantly have a clicking noise you can't find the source of.
Old October 22nd, 2018, 01:17 AM   #10 (permalink)
I will try that , because I've taken that rear tire off and I cant find any source . I kind of have a hunch it is cause by the rim. It is bent and it started when I replaced all the tires
Old October 24th, 2018, 02:55 PM   #11 (permalink)
Vehicle: 2008 Eclispe GT 6MT
#TampaEclipse is on a distinguished road
Could be a wheel bearing, which would necessitate replacing the wheel hub.
#TampaEclipse is offline   Reply With Quote Quick reply to this message
Old November 5th, 2018, 12:00 PM   #12 (permalink)
yea thats what im thinking it is. Im going to fix that wheel hub and see where that takes me
Old November 5th, 2018, 10:47 PM   #13 (permalink)
Bent rims could mean damaged hub. But usually you get a grinding or whirling noise. Or the sound of road noise gets very loud. Starting to wonder if something is loose in your spare tire compartment.
Old November 6th, 2018, 12:20 PM   #14 (permalink)
like what would be loose because it comes from outside, i believe the noise is traveling from the passenger because of the wheel hub. i have got the rims fixed but there is still a bit of road noise too and can be loud on certain roads
Old November 6th, 2018, 06:37 PM   #15 (permalink)
you'd be surprised where the sound is actually coming from when you are driving. If you still haven't found it i'd bring it to an old time mechanic, they usually know car sounds better than anyone.
Old November 7th, 2018, 08:28 PM   #16 (permalink)
Satin Meisai Gray Pearl's Avatar
Vehicle: 2007 Eclipse Spyder GT
Satin Meisai Gray Pearl is on a distinguished road
My 2007 was making a clicking noise, (front passenger side). Took it to a mechanic who replaced a bad axel shaft. No more clicking. Not too expensive of a repair either.
Satin Meisai Gray Pearl is offline   Reply With Quote Quick reply to this message
Old November 9th, 2018, 02:25 PM   #17 (permalink)
Our cars are FWD and do not have rear axles.
Old November 10th, 2018, 03:13 PM   #18 (permalink)
Super Moderator
iBlackSunday's Avatar
iBlackSunday is on a distinguished road
Clicking
I actually had something like this when I first started driving my car. I'd turn a corner, and I'd hear a thud. Was the tire iron envelope in the trunk.
Currently I have a thudding noise whenever I go over bumps. I'm assuming it's the strut mount and will be taking a look. Noises can sound like they're coming from one corner of the car and be at the totally opposite side. My first car had a bad driver side axel, replaced passenger side because it was 95% sure it was coming from that side. I was wrong and ended up replacing the driver side also.
Installed: DC Cold Air Intake | All Resonator Delete | Gutted Stock Exhaust | All Exterior + Interior LED
Maintenance: Timing belt-118k | Auto Trans Fluid-131k | Spark Plugs+Grommets+Valve Cover Gasket-125k | Passenger CV Axle-144k | Mag Oil Plug-153k
Future Work (12/10/2019): Replace Convertible Top
Last Oil Change-153,000
Valvoline 5w30 Full Synthetic + Bosch Oil Filter
iBlackSunday is offline   Reply With Quote Quick reply to this message
Old November 10th, 2018, 06:55 PM   #19 (permalink)
The Thud could be your front sway bar bushings, Currently dealing with it at the moment. Mine are frozen in place. So going to the shop Thursday to get ES bushing installed.
Old November 12th, 2018, 09:06 AM   #20 (permalink)
i have yet to replace the wheel hub, but i was out and kicked all my tires and heard that my front passenger has a sound kinda like the clicking
Old November 12th, 2018, 03:02 PM   #21 (permalink)
Keep up on it. If it is in fact a wheel hub. If that breaks at highway speeds it's not going to be pretty.
Old November 12th, 2018, 04:56 PM   #22 (permalink)
I'm well aware that these cars are FWD. I didn't say that I replaced the rear axle, I said I had the Axle Shaft replaced on the front passenger side. There is also one on the front driver's side. An axle shaft is different than a rear axle. Google is a great tool if you use it.
Old November 26th, 2018, 06:20 AM   #23 (permalink)
i fixed the wheel hub, when doing that i turned the wheel on the driver side rear and there is something in the tires so i found the source of the noise. i haven't taken it out yet but it makes sense on why it started once i got the new tires put on.
Old November 26th, 2018, 05:06 PM   #24 (permalink)
lmao, $20 says they didn't fully remove the old stub for air. or your tire pressure sensor is done.
Old November 27th, 2018, 08:24 AM   #25 (permalink)
Not sure how I missed that. Need to spend some XP on my literacy skill.
Old November 27th, 2018, 08:34 AM   #26 (permalink)
well i had them put a tpms on when i did the tires since i was missing one and they probably left the old regular air valve in the tire
No start with clicking noise/will start rarely stevenlg Problem Reports 62 July 28th, 2018 03:17 PM
Continuous clicking noise when clutch is released CanadianBacon Problem Reports 7 June 2nd, 2017 02:53 PM
Clicking noise when driving - Need input! willem445 2006-2012 Eclipse (General 4G) 3 July 1st, 2016 12:59 AM
Clicking sound in accessory mode moses1227 2006-2012 Eclipse (General 4G) 1 June 24th, 2015 03:45 PM
2001 Eclipse won't start, fusebox clicking Egememnon Problem Reports 2 July 1st, 2014 11:27 PM
