Advice on 305/30/19 Tires - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old June 15th, 2019, 10:04 AM   #1 (permalink)
KTownSpyderGTP is on a distinguished road
Hi, Folks
I have a 2008 Spyder GTP....I believe the rims in back are 9.5". Currently running 265/30/19 in back and 255/35/19 in front. I believe it's dropped 2" using Super Stock springs.
Would the 305/30/19's work? It looks like there is plenty of clearance height-wise...seems that these add about 2" to height and 2" to width compared to the current setup.
KTownSpyderGTP is offline   Reply With Quote Quick reply to this message
Old June 15th, 2019, 01:25 PM   #2 (permalink)
Check with the offset if anything that wide will rub on the fender liner or fender itself. Just measure out cardboard that long and hold it up to the tire so simulate that width.
The rims will need to be changed though. Look into some 11-12" rims for that.
Performance wise, you'll definitely lose top speed and some acceleration. You'd be way better off with a stickier tire if that matters to you. You'd also not want to run staggered on a FWD with wider in the rear though either of that matters to you
Old June 17th, 2019, 11:28 AM   #3 (permalink)
Thank you for the info. I guess I'll have to go back to the drawing board...as I can't afford new rims. What do you figure is the max tire size I can go with on the back with 9.5 rims?
Old June 17th, 2019, 03:36 PM   #4 (permalink)
275mm. Optimally 265 as the limit of you plan to abuse them at all. You wouldn't want to have the cornering force pull the tire off the rim
2008, advice, back, clearance, dropped, front, rims, setup, springs, spyder, stock, super, tire, tires, work
