Big Brake Kit 4g Compilation - Page 3 - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old April 19th, 2011, 04:15 PM   #81 (permalink)
MitEclipse07's Avatar
Vehicle: 13 Genesis Coupe
MitEclipse07 will become famous soon enough
Originally Posted by Steven View Post
Whats there website looked around but not sure i found the right ones.
here is a set:
Mitsubishi EVO 8 9 OEM Brembo Caliper Brakes F&R | eBay
and here is the evo site:
Mitsubishi Lancer Evolution | Reviews, News, Parts, Owners - EvolutionM.net
MitEclipse07 is offline   Reply With Quote Quick reply to this message
Old April 19th, 2011, 04:17 PM   #82 (permalink)
here is 2 more links:
06 LANCER EVOLUTION MR GSR BREMBO BRAKE CALIPERS EVO9 | eBay
03-06 LANCER EVO 8 MR BREMBO CALIPERS EVO9 RS CT9A EVO8 | eBay
Old May 17th, 2011, 03:11 PM   #83 (permalink)
itsreu's Avatar
Vehicle: 2004 Galant GTS
itsreu is on a distinguished road
I cant seem to remember, but why cant Evo X brembos go on our cars? i know they are bigger, but did it bolt up differently or something? I know it was mentioned on here before but i cant for the life of me find it
wtf is a galant
itsreu is offline   Reply With Quote Quick reply to this message
Old May 17th, 2011, 03:46 PM   #84 (permalink)
BlackGuard Motorsports
Isamu's Avatar
Pool Jam Champion! Plupon Champion! Dolphin Olympics Champion!
Tournaments Won: 3
Vehicle: 300zx(TT) nismo 370z(T)
Isamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant futureIsamu has a brilliant future
neat thread, but why is this a sticky?
2010 Z34 NISMO Single Turbo
Isamu is offline   Reply With Quote Quick reply to this message
Old May 17th, 2011, 10:15 PM   #85 (permalink)
Turbo GS
meDave's Avatar
Vehicle: 06-GST
meDave is a glorious beacon of lightmeDave is a glorious beacon of lightmeDave is a glorious beacon of lightmeDave is a glorious beacon of light
Did a quick search on Evom and read that the fronts work but not the rears, cuz the ebrake is different. I would do a lil more research to make sure the fronts actually do work. I only did a quick scan.
Performance: Air Research T3/T4 Turbo w/STR cast iron manifold, AEM UEGO Wideband, AEM Tru-Boost EBC, 3.0" Turbo to Axle Exhaust w/ 2.0" Dual Outlets, Ported Intake Manifold with GT TB Swap, Ralco RZ Short Shifter, RPW Thermal Spacer Kit
Suspension: Evo Brembo Swap, Cusco Strut Tower Bar, BC BR Coilovers, Progress Rear Swaybar, 4G Rear Body Brace Bar, Wavetrac LSD
meDave is offline   Reply With Quote Quick reply to this message
Old May 27th, 2011, 01:57 PM   #86 (permalink)
Vehicle: '07 9G Ralliart
monnewbie3 has a spectacular aura about
Great thread!
So to sum it up....
Brakes that fit
1. Evo 8 F & R
1.1 Wheel Mods needed:
An 18" wheel 114.3, with a +35 Offset
OR
A spacer that does a full Hub replacement. Confirmed Sizes: 25MM, ?
1.2 Additional Mods Needed:
- Brake lines?
__________________________________________________ ______________
2. Evo 9 F & R
2.1 Wheel Mods Needed:
- An 18" wheel 114.3, with a +35 Offset
OR
2.2 Additional Mods Needed:
- Brake lines?
Brakes that DON'T fit
1. Evo X Brakes
Reason: Handbrake mounted Differently?
monnewbie3 is offline   Reply With Quote Quick reply to this message
Old June 7th, 2011, 08:12 PM   #87 (permalink)
Originally Posted by monnewbie3 View Post
Great thread!
So to sum it up....
Brakes that fit
1. Evo 8 F & R
OR
- Brake lines?
2. Evo 9 F & R
OR
- Brake lines?
1. Evo X Brakes
You can use stock brake lines if you want to, but the Goodridge eclipse SS lines work perfectly as well.
The spacer isn't a hub replacement, it just goes over the stock hub and "spaces" your stock/aftermarket rim to allow enough room to fit the BBK.
I will post pictures of my BBK later.
Old June 7th, 2011, 08:26 PM   #88 (permalink)
Thanks! great to know.
Old June 7th, 2011, 09:00 PM   #89 (permalink)
TwilsonD7's Avatar
Vehicle: 2008/Eclipse/GT
So 18x8 (stock size) will fit as long as the wheel had a offset of 35 or greater? So 18x8 and a 40 offset will work?
Old June 7th, 2011, 09:10 PM   #90 (permalink)
TwilsonD7's Avatar
And if we put brembos in the front will out stock front calipers fit in the rear?
Old June 7th, 2011, 11:48 PM   #91 (permalink)
38 or smaller yes. The higher you go the more in towards the caliper you go. But it also depends on the spokes or design of the rims. Just because it says it has a +38mm offset doesn't always mean it will work.
Old June 7th, 2011, 11:50 PM   #92 (permalink)
No because the front calipers have a bigger distance between the mounting points than the rears. It wouldn't bolt up.
Old June 8th, 2011, 08:03 PM   #93 (permalink)
x-street
bullet06's Avatar
Vehicle: 06/GT/AT
You can run 17's but nothing smaller.
bullet06 is offline   Reply With Quote Quick reply to this message
Old June 8th, 2011, 08:08 PM   #94 (permalink)
TwilsonD7's Avatar
I have $1100 new tire and I'd like to keep those with new rims to fit 6 piston brembo GT.
Old June 8th, 2011, 08:27 PM   #95 (permalink)
what are the size and specs of the rims Tom? What tires did you get? I got some really sweet tires as well when i did my BBK upgrade.
You can run a 6 piston brembo setup as long as it was made for the evo 8/9. I'm running the 4 piston brembo setup and man what difference.
Old June 8th, 2011, 09:07 PM   #96 (permalink)
TwilsonD7's Avatar
Looking at falken Rt-7m 18x8 but the offset is 40 so no good...
Find Falken Wheels RT-7M custom wheels by size
They have 18x9 in a 35 offset but I can't use my tires. They are michline pilot
Old June 8th, 2011, 09:30 PM   #97 (permalink)
You could run wheel spacers worse case scenario tho, if you wanted to of course.
Ya I picked up 4 Nitto NT05's lol
Old June 9th, 2011, 10:16 AM   #98 (permalink)
TwilsonD7's Avatar
If I use spacers I'll just stick to my stock wheels, I'm going for the sleeper look.
Old June 9th, 2011, 06:50 PM   #99 (permalink)
Ya im using the evo 10 rims, same color as the stock rims so sleeper status as well.
Old June 11th, 2011, 11:56 AM   #100 (permalink)
here are those photo's:
Old August 24th, 2011, 05:18 PM   #101 (permalink)
shadow's Avatar
shadow will become famous soon enough
So will EVO X front brembos work with a 2010 gs...its just the rears that wont work correct?
shadow is offline   Reply With Quote Quick reply to this message
Old September 14th, 2011, 02:20 PM   #102 (permalink)
Vehicle: 2008 Eclipse Spyder GT
gervdog is on a distinguished road
I would like to get a larger brake kit installed, but I drive it in the winter also. How bad would it be on the brakes? Is it even worth it?
gervdog is offline   Reply With Quote Quick reply to this message
Old November 15th, 2011, 12:43 PM   #103 (permalink)
Lurking in the Shadows
blackshadoweclipse09's Avatar
Vehicle: 2009 GT Spyder
blackshadoweclipse09 is on a distinguished road
Respect to the guy with the 6-piston stoptechs
blackshadoweclipse09 is offline   Reply With Quote Quick reply to this message
Old November 15th, 2011, 12:58 PM   #104 (permalink)
x-street
bullet06's Avatar
Vehicle: 06/GT/AT
Worth it yes I love mine. There off of the evo so there good for rallying snow, dirt, gravel, tarmac so there good for what ever.
Old March 7th, 2012, 10:04 PM   #105 (permalink)
Mr. Offensive
Phantom_4G's Avatar
Vehicle: 2006/Eclipse/GT
Phantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant future
Phantom_4G is offline   Reply With Quote Quick reply to this message
Old March 7th, 2012, 10:44 PM   #106 (permalink)
Isamu's Avatar
Tournaments Won: 3
Originally Posted by Phantom_4G View Post
those are nice bro!
Old March 7th, 2012, 10:59 PM   #107 (permalink)
I'm the BEST
dejectedangle's Avatar
Vehicle: 2008 GT-SC
dejectedangle is just really nicedejectedangle is just really nicedejectedangle is just really nicedejectedangle is just really nice
Looks good I like the blue.... Where did you get the black brembo stickers
TEAM BIG SUPERCHARGERS
406 whp Evo killer
dejectedangle is offline   Reply With Quote Quick reply to this message
Old March 7th, 2012, 11:02 PM   #108 (permalink)
Mr. Offensive
Phantom_4G's Avatar
The guy who coated them just made em on site
Old March 7th, 2012, 11:29 PM   #109 (permalink)
Isamu's Avatar
Tournaments Won: 3
I am going to be selling a BBK here soon.. redone brembos from a track 350z
Old March 7th, 2012, 11:31 PM   #110 (permalink)
Isamu's Avatar
Tournaments Won: 3
who coated them?
Old April 13th, 2012, 08:26 AM   #111 (permalink)
shadow's Avatar
I'm finally a part of this.
Old May 13th, 2012, 09:04 PM   #112 (permalink)
TwilsonD7's Avatar
^ beautiful setup, now lower her!
What size rotors are all you guys using? Can you guys repost a single pic straight on showing the clearance and what size rotors you have? And wheel size
And doesn't anyone know if the stock front rotor will fit in the rear?
Old May 23rd, 2012, 08:16 AM   #113 (permalink)
shadow's Avatar
Thanks
The size rotors I am using and I am sure most people are using are just the OEM Evo Rotor size. I am running 18" rims however you can go as low as 17".
I also have +30 offset in the front and +33 offset in the rear and I am really close with my spokes. It all depends on the rim. For instance most evo oem rims are +37 or +38 i believe and they fit fine obviously because they are from the factory.
And no the front will not fit the rear because it doesnt cut out enough room for the rear emergency brake pads. Thats why the lip on the rear is so large around the lugs.
Old September 3rd, 2012, 04:34 PM   #114 (permalink)
disillusions's Avatar
Vehicle: 06 Eclipse GT
disillusions is a jewel in the roughdisillusions is a jewel in the rough
Finally got a picture up of mine!
RIP Cookie Monster 5/10/16
Welcome to North 4G Korea
disillusions is offline   Reply With Quote Quick reply to this message
Old October 20th, 2012, 09:47 PM   #115 (permalink)
Suspended Seller
Kyle07's Avatar
Vehicle: 2007 eclipse gt
Kyle07 will become famous soon enough
Here's mine, sorry picture quality isn't the best.
Kyle07 is offline   Reply With Quote Quick reply to this message
Old November 4th, 2012, 01:18 AM   #116 (permalink)
Vehicle: 350z,eclipse 2005 GT 3.8L
lohankin is on a distinguished road
My setup
Brembos from Nissan GT-R 380mm disk
they are braking like hell
lohankin is offline   Reply With Quote Quick reply to this message
Old November 4th, 2012, 01:32 AM   #117 (permalink)
Mother of God......
How hard was fitment?
Old November 4th, 2012, 01:40 AM   #118 (permalink)
4g waaat you on fire for
McClipseGT's Avatar
Vehicle: 06/Eclipse/GT
McClipseGT is a glorious beacon of lightMcClipseGT is a glorious beacon of lightMcClipseGT is a glorious beacon of lightMcClipseGT is a glorious beacon of light
Originally Posted by lohankin View Post
My setup
Nice how hard was that to swap over and where did you come across gtr brakes.
McClipseGT is offline   Reply With Quote Quick reply to this message
Old November 4th, 2012, 01:42 AM   #119 (permalink)
it was really hard )) brake disk hats front and rear are custom made on a C&C machine. Caliper adapters are custom made too. to get a gt-r calipers you definitely need a dead one GT-R )).
Old November 6th, 2012, 08:51 AM   #120 (permalink)
Vehicle: 2007/Eclipse/SpyderGt
Balzwiggle is on a distinguished road
I need some information. My 2007 3.8 spyder convertible has a warped rotor. Can I just replace it with stock parts or should I upgrade (Pads and rotors)). I don't race the car. Wife drives it to work. Might do some motorcycle rallys next summer. Thanks Brad [email protected] 608-445-1993
Balzwiggle is offline   Reply With Quote Quick reply to this message
2008, automotive, board, brake, brakes, brembo, club, drivers, evo, fitment, general, good, how to, installation, kit, oem, remove, wheels
