I have an 06 eclipse gt, didn’t start. It doesn’t have any power to the two power wires at the fuel pump, the car runs when I add external 12v to the pump. I have checked all fuses and the 2 relays in the fuse box by drivers seat. Where should I check next? Are there any good check points prior to fp? Anything that commonly goes wrong. It was at an auction so sat for a little while (if that would cause any common problems)
Thank you in advance!
How did u check the relays?
U can disconnect the battery, use DMM in Ohms mode and try to test the resistance of the wiring between points all the way from the fuel pump wires back to the furthest point, relays, etc
140whp+15.72%= 162hp
I have pulled blown relays from semi trucks. They "look" fine but are far from it... buy the relay and test it. You can always bring it bk if you dont need it.
