· Registered
It was driving fine one night got home no issuse..next morning crank but no start...check pump plugs and so on for 2 days nothing...had to have key remadeand started right up...went to store and back about 5 miles round trip...now running rough and throwing code p302...would the key possibly be the issue or just happen to be bad plug...checked all fuses and fine
· Registered
Discussion Starter · #2 ·
Forgot to add that the traction control
Traction control lights on the dash are on now
· Registered
Try to change coil from 2nd cylinder with some other. If code changes to that other cylinder (with coil from 2nd) then coil is your issue. If no, then try same with changing plugs. If no, then this needs investigated deeper.
· Registered
Thanks I didn't even think about that. When wife gets home with the go cart ill test that out and let you know when the bonfire will be lol
· Registered
Ok the coil pack is shot...took 2 and switched with 4 and pulled 4 misfire on scanner...about died when I went to get one just one pack and told 115 for just one...ugh woman is really bitching now and it's her car
· Basically Stock
