Needs a little work, I also have quite a few brand new parts I haven't gotten around to installing.
Check out this item on OfferUp. https://offerup.co/YVuBsXLDBwb
Does it run and drive? And what all parts does it come with?
Yeah if you charge & jump the battery, as long as you start it up everyday after the battery gets charged it'll keep firing up. The front suspension is pretty much all brand new (MevoTech Parts) only thing that isn't is what i have but haven't installed yet which would be driver & pass MevoTech lower control arms & inner tie rods. Also have a couple new belts, pulleys, transmission mount, extra gaskets & seals. Also have a maintenance & repair guide dvd. The spoilers is not attached but, I do have it. Just never put it back on. Lmk if you need any more info.
