So here's the lowdown:
I have changed the camshaft sensor/crankshaft sensor, thermostat, coils, spark plugs, coolant, cleaned MAF, cleaned throttle body, put new clutch and throwout bearing. Oil is topped off good and no real leaks.
The car drives real good for about fifteen minutes and then at a full stop dies and doesn't want to start back up, unless I let it sit for about 20 minutes stranded. The car will shoot P0340 codes for cam and crank shaft sensors, and then another for random misfires detected. I don't see any bad wires but ill have to strip it down and take a closer look at the wiring. I'm just at a loss for words, I've replaced both sensors and I'm still getting stalling and rough starts, then the cam and crank shaft codes??? Any ideas and help will be appreciated...thanks!
