This is how everything went: first the resistor pack went out and all I had was high (4) on the fan. The A/C compressor would kick on, as shown by the green light on the switch dial, when the switch was set at 1,2,3 but the fan didn't work, When I switched it to high, the fan went on but the A/C went out. I replaced the resistor and everything worked fine. I noticed the A/C wasn't getting quite as cold as it should so I added a little freon and brought the pressure up to where it should be. The A/C ran for about two hours and then the compressor clutch stopped engaging. The green light goes on, but no A/C action. This was in the fall, so I wasn't too worried about looking into the problem right away, since the heat works fine. A month later a brake line popped right at the bend where the firewall and the floor panels meet. It got very cold about this time and I don't really drive this car much in the winter, so it was up on stands for a month and a half before I got the brake line fixed, along with new rotors all around and new calipers on the front. The day I completed the brakes I noticed the stereo didn't work and I would get that "e com" error message. So now, the bearings on my alternator burned up and my belt tensioner was froze up. I got all of that fixed and I figured since I am wrenching on the car anyway, I would look into the A/C and stereo problems. One thing I did when I had the alternator out was disconnect the plug to the compressor and put a meter between the incoming line and ground and turned on the A/C... I got no voltage on the line. Not to mention I get continuity between the wire to the compressor and ground. I didn't check the actual resistance, but it isn't a dead short so I figure the coil in the compressor clutch is good
