1 - 1 of 1 Posts
Trying to determine source of transmission noise; See below or this thread
www.club4g.org/board/cars-sale-wanted/121099-2006-gs-5-speed-trans-noise.html#post1920375
Make a difference as to whether I keep and repair or let the car go ! Any input appreciated !!!
Makes a bearing noise when clutch pedal is up (engaged) goes away when I push down on the pedal (and in Neutral & start the car, before I shift gears. Been told might be "input bearing".
>>>That'll be the clutch release bearing
>>Umm are you sure ? Noise is when pedal is up, and in neutral ( engaged like the drive train and trans are married). When I depress the pedal it goes away. Everything I know and read says it's the "transmission input" bearing.
Means opening the transmission. Not just s new throw-out (pilot) bearing.
See this thread
1 - 1 of 1 Posts
