1 - 11 of 11 Posts
good morning guys, I'm new to the forum, I'm sorry if this is not the right place to post about a problem I'm having with my car,
2007 Eclipse GS 4 cylinders (2.4) runs great but at times it dies on me I could driving down the road with my foot in the gas pedal and it dies, or I could be in a stop light and suddenly dies this is being going on for over a month now, after some time and it's always different it could be just a couple minutes to up to 15 minutes and it starts again car does not have the muffler,check engine light sometimes comes up for a few days then it disappears I took it to autozone and it read something about the oxygen sensor and heating on the exhaust system I'm not really sure exactly what it read it's been a while and I threw the paper away
I need suggestions please
That's not a normal O2 sensor failure.
Find what the actual code is. O2 sensors readings shouldn't have enough fueling control to actually stall the engine.
Yeah I just gave that advise because he mentioned exhaust heaters, I thought he meant a code for the O2 sensor heater circuit
Super Moderator
I never had an issue with my car literally dying with my cat clogged, but does it seems like it dies instantly, or does it chug? If it dies instantly, I would pop the hood and start wiggling wires around at the plugs to see how the car reacts (Wiring harness wires). I had an issue where a sensor in my car had bad wiring from the wire to the plug and I figured it out by literally wiggling the wiring at the base of the plug. It's a good idea to do this, mostly the ones around the timing belt and the alternator is where my problem was.
Same thing has happened to me before. The car would just die as I'm driving but luckily I have a manual so I would pop start it right away as my car is moving. It was from a loose battery terminal that would move around as I'm driving and come off/loose. I can suggest u check your terminals and tighten them.
hey guys sorry I haven't reply back to you, I'm still having the same problems with my car I don't drive it any more kinda been driving the wife's car whenever I can lol, but any way back to the my car, to answer some of your questions, when the car is running nothing else seems to be off everything is normal, I could have my foot in the gas pedal and car would just die on me, the times that it dies is at random I can be driving the car for 5 minutes and it dies or 2 hours and it dies and when that happens I sometimes have to wait up to 30 minutes for it to start
the battery has enough juice to start the car be cause when the car dies and I try to start it back up it tries to start you can just hear the engine not sucking up enough fuel
Discussion Starter · #10 ·
I used to think that's what it was I even change connectors and car was running without problems for like a weeks then it started doing the same but yeah it was really bad with the old connectors that I actually thought that was the problem but since I changed the connectors it's not as bad but I still have the same problem,
another question I've notice there's a 120 amp fuse that comes from the alternator do you guys know if I have to have it there? cause I was thinking may be that could be the problem too
1 - 11 of 11 Posts
