I hope someone can help me with an A/C issue. The air conditioner blows very hot heated air, not outside ambient warm air on all settings. The A/C light is green, the compressor engages and the lines under the hood are cold. The fan works on all settings. When the key is turned on there is a sound in the dash for 10 seconds that sounds like a pump or motor running, it is a new sound that is pretty loud. I suspect that inside the plenum a door is stuck but I have no idea where to look or how to find it. Any help would be appreciated.
My 2006 model has the same issue! The buttons on the steering wheel, CD player and the cruise control stopped working at the same time. Hopefully we can get some answers!
It was the door inside the air box not moving. The mechanic replaced the actuator far back in the dash. $50 for the part, about $500 labor. Quoted it as a 6 hour job, had to remove the entire dash.
