new to the 4-g and just purchased one with problems. what should the fuel trims be? car has a stumbling idle and if try to drive hard falls on its face if you stomp it. cuts completely out till you let off . if you ease into it you can take right up to redline. only code is random misfire.short term fuel trims are around 12 and trying to drop down. help an old tect out been retired for 20 years and haven't kept up with obd 2.
another problem when sitting still after a couple minutes the traction control will cut off (light comes on) switch it off and restart same results:hail:
