I have 20 on mine... can't suggest it.the ride is terrible. The tires are expensive but the wide tires grip like hell.
Imagine now if you had the same width of tire, and the tire had some sidewall flex so it could confirm entirely to the ground instead of have tread press unevenly.
You'd grip even harder. Hard springs to deal with roll and sidewalls to conform to the road is what you see in high end racing where every bit of grip matters.
