i got a question do 2G eclipses fit onto a 4G eclipse. i have a couple people selling me manual transmission coming from a 2G eclipse with low mileage and no grinding or damage. if i were to buy this would it fit good or will it not fit at all?
I sincerely doubt it. Maybe a 3g transmission would work, but even then it would just be easier and less expensive to get a transmission that came as an option for the 4g. IE maybe just find a 4g 5spd?
2006 GT Manual.
2g mount with the trans on the passenger side. Everything is backwards.
3G and Lancer trans for 4G6# engines work. 1g and 2g are outliers in the Mitsubishi world
The 2g base, rs and gs are backwards.They run a 420a chrysler engine and trans. The gst and gsx mounts the same way.
Are you sure, because when I look at pictures, they aren't. Eg, this is shown as a 95 GST
Motor vehicle Vehicle Automotive air manifold Auto part Car
And here's a 1998 GSX
Car Motor vehicle Vehicle Automotive design Automotive air manifold
And this is what I get when I look up 420a. It mounts the same, but isn't the same family of engine, and is a different bellhousing pattern than the 63 on the 1G/2G, or any other 4G6# engine
Motor vehicle Car Automotive design Automotive air manifold Vehicle
2006 GT Manual.
Ok im sorry. I had them backwards. The gst and gsx (4g63 cars) are backwards. 420a cars are the same orientation. Either way the 420a is a completely different engine.
