1 - 20 of 38 Posts
here are the specifications for all trim levels of the 4G eclipse.
Eclipse GS: Base FWD model equipped with a 162 hp 2.4 L 16-valve SOHC Mitsubishi 4G69 engine
Eclipse GS Spyder: Convertible FWD model equipped with a 162 hp 2.4 L 16-valve SOHC Mitsubishi 4G69 engine
Eclipse GT: Hardtop FWD model equipped with a 263 hp 3.8 L 24-valve SOHC Mitsubishi 6G75 engine
Eclipse GT Spyder: Convertible FWD model equipped with a 260 hp 3.8 L 24-valve SOHC Mitsubishi 6G75 engine
The models and standard / optional equipment:
GS Standard- Choice of five-speed manual or Sportronic® automatic transmission, a 140-watt (max.) Mitsubishi CD/MP3-compatible audio system with six speakers, 17-inch alloy wheels, an anti-theft immobilizer, auto-off halogen headlamps, power windows/locks/mirrors, air conditioning, a split fold-down rear seat, two 12-volt accessory outlets, anti-lock brakes, a rear spoiler, and a six airbag safety system.
Options Include- Sun & Sound package with a power sunroof is paired with a 650-watt (max.) Rockford Fosgate® audio system. Boasting nine speakers including a 10-inch trunk-mounted subwoofer, a 6-CD in-dash changer, and steering wheel-mounted audio controls, the package also includes a center display with outside temperature and compass readings and an electrochromic rear-view mirror. A four piece body kit comes as an optional "aero kit" package for all models.
GS Spyder - available for sale for the 2007 model year.
Options Include - GS Deluxe Leather Package: Leather front seating surfaces. Heated front seats. Heated side mirrors. Outside temperature indicator and compass in center dash display.
GT Standard- Choice of six-speed manual or a five-speed Sportronic® automatic transmission, a 140-watt (max.) Mitsubishi CD/MP3-compatible audio system with six speakers, 17-inch alloy wheels, an anti-theft immobilizer, auto-off halogen headlamps, fog lamps, power windows/locks/mirrors, air-conditioning, a split fold-down rear seat, two 12-volt accessory outlets, 4-wheel anti-lock disc brakes, a rear spoiler, dual-stage six airbag safety system, traction control, a front strut tower bar, and a center display with outside temperature and compass readings.
Options Include- Premium Sport Package with 18-inch seven-spoke alloy wheels, leather front seating surfaces, a power sunroof, an eight-way-adjustable (six power) driver's seat, alloy pedals, heated front seats, heated door mirrors, automatic dimming rear-view mirror, air-conditioning and a 650-watt (max.) Rockford Fosgate® audio system with nine speakers, including a ten-inch trunk-mounted subwoofer, a 6-CD/MP3-compatible in-dash changer, steering wheel-mounted audio controls.
GT Spyder - available for sale for the 2007 model year.
Options Include - GT Premium Sport Package: 18" Alloy wheels. Leather front seating surfaces. 6-way power driver's seat. Heated front seats. Heated side mirrors. Aluminum pedals. Automatic climate control. Wind Deflector
Wheelbase: 101.4 in (2575 mm)
Length: 179.7 in (4565 mm)
Width: 72.2 in (1835 mm)
Height: 53.5 in (1360 mm)
Track (in. front/rear): ALL- 61.8/61.8
Curb Weight(lbs.,MT/ST): GS-3274/3307 GT-3472/3538
Weight Distribution (front/rear): GS-60/40 GT-62/38 MT, 63/37 ST
Stabilizer Bar (mm., front/rear): GS- 22.0/20.0 GT- 22.0/21.0
Steering Wheel Turns, Lock-to-Lock: ALL- 2.64
Steering Ratio: 17.1:1
Turning Radius: 20.0
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in., front/rear): 11.6/10.3
Fuel Mileage Estimates
5-Speed Manual - City/Highway (mpg/mpg): 23/30
6-Speed Manual - City/Highway (mpg/mpg): 18/27
Sportronic® 4-Speed Automatic - City/Highway (mpg/mpg): 23/29
Sportronic® 5-Speed Automatic - City/Highway (mpg/mpg): 19/28
Fuel Tank (gal.): 17.7
Recommended Fuel: GS- Regular Unleaded GT- Premium Unleaded
Interior Measurements
Headroom (in., front/rear): GS-38.5/34.6 GT-38.5/34.6
Headroom with Sunroof (in.,front/rear): GS-37.5/34.6 GT-37.5/34.6
Leg room (in., front/rear): GS-42.8/29.2 GT-42.8/29.2
Shoulder Room (in., front/rear): GS-54.2/51.2 GT-54.2/51.2
Hip Room (in., front/rear): GS-53.7/44.4 GT-53.7/44.4
Cargo Volume (cu. ft): GS-15.7 GT-15.7
Passenger Volume (cu. ft.): GS-81.6(80.2 with sunroof) GT-81.6(80.2 with sunroof)
Engine Specific
Engine Type: GS-I4 MIVEC GT-V6 MIVEC
Engine Block: Cast Iron
Cylinder Head: Aluminum
Displacement (liters): GS-2.4 GT-3.8
Horsepower @ RPM (BHP): GS-162 @ 6000 GT-263 @ 5750
Torque @ RPM (lbs-ft): GS-162 @ 4000 GT-260 @ 4500
Redline (rpm): 6500
Bore x Stroke (mm): GS-87.0 x 100.00 GT-95.0 x 90.0
Compression Ratio: GS-9.5:1 GT-10.5:1
Valvetrain: GS-SOHC 16-Valve GT-SOHC 24-Valve
Performance Specs
Manual GT- 0-60mph in 6.8 seconds, 1/4 time 14.9
What Drives You?
Just curious - where exactly did you get this info? Some people might dispute those 0-60 and 1320 times :)
"Yayo"
And I'm curious as well.. How is it that the 6sp gets worse gas mileage than the 5sp and the 5sp sportstronic worse than the 4sp sportstronic? To me that makes no sense at all?
all of the spec information i got was directly from mitsubishi itself. as for the 0-60 time, that was a road test conducted when the car first came out. i know that there are a lot of variables involved, but that is pretty much what is listed for a stock GT 6-speed.
that is why it is called "estimates" :biggrin:
i think thats because the five speed is a 4 cyl and the six speed is a GT
"Yayo"
Yeah; I forgot that they were different engines, all I saw was 6sp vs. 5sp at the time. I've since realized this, lol. :)
The dick of JUSTICE
turning ratio is definitely in the top 10 of things that will drive you nuts about this car.
My dad's Dodge Caravan had a better turning ratio then my 4G. Ironically that Caravan had the same engine as a 3G (6G72).
BlackGuard Motorsports
Curb weights, per Mitsu:
GS 2.4L i4 coupe:
5MT = 3,274 lbs (1,485 kg)
4AT = 3,307 lbs (1,500 kg)
GT 3.8L V6 coupe:
6MT = 3,472 lbs (1,575 kg)
5AT = 3,538 lbs (1,605 kg)
What Drives You?
nice paraphrase :lol:
I love To Drift
I could be wrong about this, but I think part of the list is sort of incorrect.
Because from what the dealers told me the 06 & 07 GT have 260 hp an the ones after that the 263.
1 - 20 of 38 Posts
