I peeled tires when accelerating from a stop sign, I gave it alot of gas but it was also raining so the ground was wet. I doubt the tires would've done that if it was dry. While doing so my ABS an traction control lights came on an stayed on until I turned the car off an started it back up. I was wondering if cheap abs sensors from rock auto could be the cause or if the ground being wet could've caused it.
102538
Prob has history codes stored in the ABS unit from some bad data from the sensors going haywire, it’s not seeing the issue right now so the light went off but it is still an issue
