I have a 07 eclipse se 2.4 l while removing the radiator in my car I noticed that the ac condensor was only mounted to the top of the radiator the two Lower brackets were not mounted to anything which is what caused my radiator to leak because of the lower mounts not mounted caused rubbing on radiator the only way I can see it would possibly mount is mount to side of radiator is there a special set up how do I mount the lower brackets to radiator without damaging the radiator
