AFR
472 Views 3 Replies 2 Participants Last post by  Sabertooth^2
Część, w którym banku najlepiej zamontować szerokopasmową sondę AFR w 3.8G?
Neither. Mount it after where the two banks meet. About 30cm back.
Next time, it would be good to try upping the heat setting on your welder, and focusing more on the O2 bung base than the pipe material below. It'll still pump in plenty of heat to the pipe, and you'll get better fusion rather than lay material just on top. You won't be chasing burn throughs as much either.
  • Like
Reactions: 1
