Auto To Manual
964 views 2 replies 3 participants last post by  Sabertooth^2
#1 ·
Need some help, does anyone have a step by step on how to auto to manual guide? And parts list of what’s needed? Some say I need manual ecu and harness while others say I don’t? Also not looking to buy a 4g manual since there’s none in my area, been looking on this forum but haven’t seen any answers
#3 ·
If you want everything to work right, the cheapest way to get the parts needed is to buy a manual car.
My friend did this swap. Things that changed include:
Pedals
ABS
Brake Master cylinder
ECU
Engine harness
Body harness
Shifter assembly
Shift cables
Center console
ETACS
ECU
Transmission
Axles
If you want to do it sloppy, you can avoid changing wiring, ECU, ETACS, ABS, cut a hole in your center console
The only affordable way he found to do it was to buy one that had been in a collision. Otherwise it was going to be cheaper to buy a running good condition GS manual than the parts alone.
