I picked up the Aux input cable from the stealership for $22 + tax. the part number is MZ360135EX. The install was easy, took less than 10 min. I'll post the pics as soon as I get home.
The front cover of the 6 cd changer just pops off I grip it from the bottom you can use a panel lift bar or a screw driver if it feels tight...you can get a panel pry bar at pep boys It doesnt have sharp edges so you don't have to worry about scratching anything. Once it comes off just remove the four screws holding the stereo in and then you'll see the 22pin dilio and then your home free. Good luck with that!!!!!!i have a 2007 eclipse spider, how do i open the cover of the stereo to reach the the back so i can install the aux input cable, which tools do i need? i am a girl and dont want to break anything
thanks![]()
FYI:Thanks a lot, i will do it as soon as i receive the cable and i will post it
Is there any solution for the standard CD players that don't go into "AUX" when holding down the CD button??the MIT-POD only works for the 6 cd changer setup. it works great, just as clear as playing cds.
