AS OF NOW, THIS INFORMATION IS ONLY FOR CLEANING THE BLOWER. I will add more about the electrical aspect if I can figure it out.
To start, I checked all fuses that relate to the air controls, both inside the car and under the hood. No Problems.
Tools:
Phillips Screw Driver (you will need a short one for part of this)
Large Flat Head Driver
Hands and Beer (I mean patience)
Long Post Part 1:
I DO NOT SUGGEST DOING THIS FIRST PART BECAUSE IT IS A PAIN (unless I discover something later down the road)- Last night i removed the air control face (pulls straight off) and disassembled the unit (4 or 5 phillips screws, and a bunch of T10-torx screws). I looked at all the electrical components to see if anything was fried. I saw no visible signs of problems but I never measured anything with a meter. I took apart the switch and cleaned the contacts. I used a jumper wire to test the contacts. Everything is functioning properly as far as I know at this point.
Part 2, Important Part:
Today I removed the glove compartment to access the blower. (If you do this, be ready to sit completely the wrong way in your car. Its kinda like one of those awkward things you and your girl might try.)
1) Remove the glove box (remove the string on the right side that supports the unit. The whole clip slides off). There are three hinges that can be removed by using a flat head driver to press upwards on the part attached to the glove.
Glove Box Hinges:
Pivot Point Under Dash:
2) Behind the glove box is another cover that can be removed by removing 4 screws and carefully pulling towards the rear of the car (sorry 2 screws arent in the pic but they are near the red lines).
In:
Removed:
You do not have to remove this, however I did so I can see the whole wire harness.
Harness:
3) You need a small phillips screw driver (I used a ratchet driver) to remove the cover under the blower. 6 screws: 3 are easy, 2 hard to reach, 1 is a b*tch.
Cover:
4) Unplug the blower (two black wires w/ plug n play connector). There are 3 torx screws that are also made to be removed with a flat head. The blower will drop straight down.
Screws:
Blower Removed:
5) I used ear-swabs to clean every fin because the blower would vibrate and it was annoying. Hoping it is the dust causing it to be unbalanced. Also, I vacuumed the recirculation filter from the inside the vent.
Filter:
Tomorrow I will look at the electrical aspect. Hope this helped somewhat.
