I have been having intermittent issues with idle surging. First noticed it when trying to free up a sticky calliper piston and I was pumping the brakes a bunch. It’s getting worse, sometimes it happens stopped at a light with the brakes on.
I think I have it narrowed to the brake booster check valve (the vacuum hose was getting dry too).
Does anyone know if the check valve can replaced on its own or does the entire brake booster have to be replaced? Is it just threaded into the body of the booster?
