My son in law just bought a 2007 eclipse 2.4l 4 months ago with 150,000 miles but didn't do the timing belt service right away. It snapped while he was driving going about 40 mph. The balance shaft belt did not snap as well. We rotated the crankshaft until the timing mark lined up and the balance shaft lined up on both their timing marks and then rotated the oil pump pulley until the timing mark lined up for it and put an Allen wrench through the front bolt hole to make sure it moved in and out freely. Then rotated the camshaft until it's timing mark lined up. Reinstalled a new timing belt kit and the car was able to turn over but runs extremely poorly making many popping and knocking noises from the engine and exhaust and will not stay on unless the gas pedal is moderately depressed. So I thought we would get a cylinder head from the junkyard, clean and resurface it, and line up it's timing mark and put it on with a new head gasket kit and head bolts. Does this seem reasonable to fix the car? Is there likely other damage? How possible is it that something happened to the pistons as well that would need to be fixed? I was assuming any damage to them would be negligible and not really matter much. Is this correct? Any advice is appreciated especially from others who may have gone through this as well. Trying to fix it for cheaply as possible as he has still has a loan on the vehicle and can't just get another yet.
