Installment #1
Joined up here a cuppla months back, lurked a bit while I studied some of the particulars of the 4G platform while I was looking for a suitable 4G GS Eclipse. Started a thread about the ‘07 I was buying and then have been conversing privately via email w/Sabertooth^2 about my build plans. BTW, he’s been a great help in all this and deserves a BIG thanks for all his help!
Ok, so a little long winded back story and then we’ll move on to the actual turbo build parameters for the ‘07 Eclipse GS I picked up in 2-21 in the next installment.
Started playin w/cars a bit late since I was already 30 when I began modding. Started back in the late 80s w/a German built ‘74 Ford Capri w/a 2.0l SOHC motor, same engine used in the Formula Ford race series.
Played with it, tweaked it with stock parts until I finally hit the performance wall and started making refinements to the stock stuff and eventually repurposing other cars parts and aftermarket stuff to improve the cars performance.
Ended up with a little 2.0 that screamed like a banshee and revved like a bike motor with handling that made it feel like it was on rails. This car was light, like 2200lbs, so even with less than 200hp it was a blast to drive, until … I got T-boned by a catering truck. Didn get hurt but the car was toast.
Next up was a ‘78 Ford Courier w/a 2.3l SOHC engine. Played with it for a cuppla years but the pressure from my then GF was too much to bear so the modding stopped at a rebuilt short block, cam, header and exhaust, improved ignition, and a bigger carburetor.
Then I went into a performance hiatus for a few years till I bought a ‘92 NA 4g63 DOHC 2.0l Eagle Talon in ‘96. This package had everything I’d dreamed about doing to my Capri and more as stock equipment. DOHC 4 valve head w/roller rockers, computer controlled engine management, fuel injection, oh man, I was in mechanical heaven!
Having had it for about 6 months and during one of our hottest Texas summers on record the thermostat stuck closed and with the outside temp at 110 in a matter of minutes the show was over and I was now the owner of a dead Talon. It got so hot that when I popped the hood it was pulsing oil and coolant out from between the head and the block, which was quite a sight.
At the time I was just beginning to surf the ol www. so I decided to see what I could find as a long block engine assy to just drop it in and get the Talon back going again. Lo and behold, when I did a search for Eagle Talon I found there was a wealth of information, clubs all over the world and a thriving aftermarket for these cars.
Anyway, found a used engine, had it shipped in, dropped it in and did my 1st timing belt swap. Doing that swap and realizing the precision with which the engine was built and timed, I was hooked and fell happily back into the modding game again.
Joined a local DFWDSM group and surfed and studied about these awesome lil 2 liters. Began conceptualizing what I wanted to do with the Talon but was always stonewalled by all the local DSMers whose mantra was always “Sell it and buy a turbo car, modding an NA is a waste of time!”
Being a bonified hard head I just went my own way and eventually wound up with an NA 4g63 that could even top end a stock AWD AT Talon TSI (turbo) a buddy of mine had. And, while many of my buddies cars were constantly sittin on jackstands while they repaired this or that or were waiting for parts mine was out terrorizing the roads around DFW on a daily basis, havin fun, rackin up tickets, you know, the usual.
During all this fun myself and 4 other DSMers opened up a small performance shop and called it Bar None Motorsports. We all had full time “real” jobs and did our shop stuff late into the night in a one bay storage building, then eventually into my 2 car garage with an attached 4 car car port.
Our focus was on building dependable hot street cars and always turned down anyone who wanted to build a drag car project. We had loads of fun and built some really fun toys but eventually split up over the concept of opening a full time shop.
The vote was 3 to 2 for opening a real shop while I felt we needed another year or 2 under our belts to make it a viable operation with a big enough following to enable us to make a go of it. BTW, the other 3 never did open a shop, so that was the end of Bar None Motorsports.
Between then and now I did a few other projects for customers and have owned DSMs ever since along with a cuppla Mirages and my trusty Dodge Ram pickup.
These days I’m single, in semi-retirement, still working, though far afield of my realm of industrial equipment mechanicing and have finally started drawing social security. My bills are cheap, everything’s paid off, have no debt so most of my $$ can go towards my toys, wooohoo!
All the above leads me back to my ‘07 4G GS turbo Eclipse project. This is very likely to be at least one of my last hot rods so it’s gonna be one tricked out MoFo for sure!
As a tribute to my old ‘74 Capri the ‘07 Eclipse project will be dubbed The Rolling Toy Box which is what I called the ‘74.
This build will take a while but I plan to throw every trick I’ve learned along the way into this build with no stone left unturned! Along with the turbo engine build every wearable joint in the suspension will be replaced and the overall suspension system upgraded w/coil overs and sway bars and it will all be as well documented as I can make it, so get ready to have some fun!
