Climate control issue 2008 eclipse gt
2K views 15 replies 4 participants last post by  pcfreak4
#1 ·
Hello!
My issue is that everything works fine on the temprature control unit ( fan speed, blower direction) except the temperature. When I put the knob at max heat I get max heat but anything else, I get the same warmish temp. It does not matter if I put ac on or off. I recently asked a mechanic to check if my ac was leaking but it was fine and he filled it. Right now, I am pretty sure the problem is electrical and that I need to change the temperature control unit but I want to know if there is a way to be sure it is the issue before I buy a 150$ piece. Thanks!
#2 · (Edited)
Hello!
Prob a sticking diverter valve/blend door in the dash or something
Need scan tool that can scan the A/C system for fault codes
