I just did a compression test on the rear cylinders, they all read 200 psi, and the front read 240 psi. What could be causing that difference and what is the compression suppose to be at?
That sounds really high are you sure?I just did a compression test on the rear cylinders, they all read 200 psi, and the front read 240 psi. What could be causing that difference and what is the compression suppose to be at?
Yes, we went around 2 times just to verifyThat sounds really high are you sure?
Hey bro, how did you go about doing the compression test? Obviously you had to remove the intake manifold?I just did a compression test on the rear cylinders, they all read 200 psi, and the front read 240 psi. What could be causing that difference and what is the compression suppose to be at?
WITH THE CAR HOT:Hey bro, how did you go about doing the compression test? Obviously you had to remove the intake manifold?
