So, within the last couple of months my door locks stopped working.
Symptoms:
Key does not work
Electronic lock button in the door doesnt work
-- when either of these actions are taken, it makes a sound, and the locks TRY to click over, they even physically move, but they dont actually lock or unlock.
Troubleshooting completed so far:
Checked the door lock fuse in the engine bay (the 40amp one) and it appears fine.
There is also what appears to be a door lock fuse in the cabin of the car, (#15) and it appears to be fine as well.
Unhooked my aftermarket viper alarm.
The only thing I can think of is that the JDM Black housing LED Taillights I installed a few months ago are causing an issue. Originally the only thing that did not work was my cruise control, and that stopped working pretty much immediately after I installed the taillights, it wasn't until about a month or two later that the door locks stopped working.
I know I should have already put the inline resistor in with my taillights (which I found a tutorial for on here) but I just havent had time recently, and plan on getting that done this coming saturday.
My car is @ 55k miles, it's a 2007 GS, so while it's still under the 5 year mfg warranty, the mileage is over, so it won't be covered for a mfg repair. Even if it was I have a feeling they wouldnt fix it because of the aftermarket lights.
Anywho, does it sound like a problem that might be fixed when i put the resistor inline with my taillights? If not, any ideas on what it could be?
Thanks!~
Symptoms:
Key does not work
Thanks!~
