1 - 5 of 5 Posts
I have a 2008 Eclipse GS. I'm having trouble with my lock actuators. I have been unable to find a maintenance manual at the local parts stores. I've purchased the actuator motors to rebuild the actuator. However, I am having trouble removing the inner panel of the door. When I remove the bolts, I can raise the rear part of the panel about 4 inches, but the front only moves a half inch or so and seems to be caught on something. The posts I have read here have links to pictures that when I try to access I get a error message. Any help would be greatly appreciated. Thanks
Jeff
there is a plastic square behind the handle. pop it out and remove the screw. you have to pop the front of the puller handle and remove the 2 screws there
Thanks for your help. I was able to get the door panel off and the replaced the motor in the lock actuator.
1 - 5 of 5 Posts
