Hey guys, just got myself an automatic 2012 eclipse spyder gs.
The mechanic said I need new engine mounts and transmission mounts, any recommendations on which ones I need to get?
Thanks!
Welcome to the club
Take your pick, only the Energy Suspension are stiffer than stock. If it's the driver's side trans mount, that's a tricky one to get as a non-performance version.
Welcome to the club
I get kinda confused, how many engines mounts does it has and how many transmission mounts?
The engine and trans are connected. Don't worry too much about the semantics. There are 4 mounts total. Front, rear, driver's side, passenger side. Front goes to the trans but is usually called a motor mount. Rear goes to the trans but is usually called a motor mount. Passenger side is engine only. Driver's side is trans
Discussion Starter · #5 · (Edited)
The engine and trans are connected. Don't worry too much about the semantics. There are 4 mounts total. Front, rear, driver's side, passenger side. The front goes to the trans but is usually called a motor mount. Rear goes to the trans but is usually called a motor mount. Passenger side is engine only. Driver's side is trans
got it! Found this, that's all 4 right?
A4624 9305 EM-9305: Front Mount
A4628 9281 EM-9281: Front Right Mount
A4629 9382 EM-9382: Rear Mount
A4656 9691: Manual Transmission Mount
one of them has manual in the name which throws me off
Light Black Camera accessory Font Sleeve
I've never owned an auto eclipse, so can't speak to any truth about a manual and auto mount being the same. The pressed in bushings should be though.
If you're handy, you also could still out the rubber a bit and pump in construction urethane. $10 fix, and stiffens the mounts beyond stock easily. That gives better handling, and reduced torque steer, not that torque steer is a big issue on a GS auto.
