My 09 GT was letting in water and I couldn’t find much information on this particular kind of leak. As these cars get older rear leaks like this may become more prevalent. Hopefully this helps someone.
Leak is located primarily in one of the two corners of the car above the rear seats and triangle windows. Mine was on the passenger side. I noticed saturated headliner, water under the rear seats, and my trunk was filling with water when it rained heavily. When it would rain the water was actually visible dripping down the back panel under the removed pillar in the pictures.
I found and followed this YouTube video:
He was having a similar problem. This however did not fix the leak and made my hatch look a little sloppy.
I thought the water was possibly getting by the gasket and getting into the seam to cause that rust. As you can see in the second photo the water is still coming through where the two panels meet. Able to see when pulling down the headliner. This was where the leak was always coming from.
Slight cracking on the seam going up to the roof drip molding. This is the channel water runs down toward the back of the car to drain. I tried sealing the cracks with Flex Paste. After it was dried I tested with a hose and the leaking was slowed down.
Next I removed the black drip molding on the roof of the car. This was easy to remove as it’s just held on with double sided tape. I cleaned up the tape residue with goo gone.
Finally found the main culprit. I first filled in the scratch I made accidentally with touch up paint and clear coat- so the roof wouldn’t rust. I filled in all cracks again using Flex Paste
There was a small crack starting up front that I also covered but didn’t get a picture. I hadn’t had a leak in the front but wanted to be safe. After some testing the next day I determined the inside was finally dry. Reattaching the drip molding was easy enough with some good double sided tape.
It’s been a few months for me and the car has been bone dry
If water is getting inside your car I would try to act quickly to save your interior and prevent the roof panels from getting wet and potentially rusting out areas that aren’t visible which could end up being hazardous- like the roof seams.
User BrianJ seemed to have had this issue back in 2008 and had it fixed by Mitsubishi themselves.
www.club4g.org
I apologize if I’m posting this in the wrong place
DIFFERENT Water leak problem...Structural problem
Ok guys, I've had the guides in the sunroof replaced for the water leak by the sunroof button...it doesn't leak there anymore. HOWEVER, there was also water in the BACK of the car...they thought the guides would solve this as well, but no luck. Here's the deal. On the passenger side in the back...
