I've been messing around with a cheap LED strip from amazon on my rear spoiler. Tonight I cut the strip about 1 inch from the end, trying to make it fit and when I tested by hooking it up (it's wired to a controller box which is connected to both brake light wires).
My car no longer starts.
When I lock the car using the key, it locks but doesn't flash the blinkers nor does it honk.
When I use the turn signal, nothing happens.
If I turn on the hazards button, my inside light flashes.
If I turn the key to the on position, the open door light correctly comes on and I get the chime, and my radio works, no other lights come on on the dash (can't remember is that's normal, but I think not).
When I turn it to start, it doesn't do anything. The dash is completely dark. No clicks, no starter attempts, it's like a dead battery.
I don't think the battery is dead (it wouldn't explain the turn signals and hazards) and I tried my lithium jumper just to see. It didn't try to turn over with that hooked up either.
Any ideas guys? Do you think I fried my computer? If I did, is it a big deal to replace it? I see some used ones for under 100$ and new one is over 300$, but is there any issues with changing it out? Am I even on the right track?
Sabertooth? HELP BRO!?
