Hello! I'm installing Tein S-Tech springs (Which everyone on this forum seems to love) on my 4cyl '07 eclipse. I got past the brutal bolt holding the tie rod in the front and i've run into a problem I was hoping someone would have some insight on.
When trying to take apart the whole strut the top bolt (self locking nut i believe) just keeps spinning around, and the cover stops me from being able to use two wrenches or having some room to mess around with it.
If i wanted to use something to hold the cylinder inside the strut, i'd be buying four new cylinders.
ANYONE whose done lowering springs, i'd love to hear about how you got around this to remove the stock spring and put in the aftermarket. (my car is currently on wooden blocks, and i'd rather it be lowered, on rubber tires)
cheers in advance
cheers in advance
